Question about Refrigerators
I have a lg model number lfd22860tt and the refrigerator lamp cover melted and fell off. when i called they told me there was a issue with these and they are being changed to a new kind of light kit that doesn't get as hot, why did i not receive a recall notice on this and can it start a fire, i took the lamp cover off and i am on the list for a service call.
The same thing happened to mine. The reason it happened was that one of 2 push button door swiches failed and didn't shut the lights off when the doors were closed. They were on for hours and caused the lamp cover and housing to overheat and greatly distort. Parts cost over $100.00
Posted on Apr 30, 2009
SOURCE:
The refrigerator lamp unit did not shut off when the double doors were closed and caused the lamp to overheat. It burned the lamp itself as well as melted a hole above it in the top through to the...
If this is a lg our the model number starts with 795, it should be fixed for free. There is a known issue, needs a service kit. Comes with main pcb and light sheild. Call sears back and tell them you have a service flash 46-515, I think that's the number. They should take it from there .
Feb 20, 2013 | Refrigerators
How to fix light not going off in refrigerator
Replace the main pc board. Was part # 6871JK1011C, with a 5 amp light relay, now should use the new board, part # 6871JK10011F, with a 16 amp light relay, which will prevent relay contacts from welding themselves together. Should also replace the lamp socket harness with part # 6621JK2003B which now has a thermostat on it to prevent lamp from overheating and melting lamp cover. Contact a locally authorized LG servicer or LG directly to have the servicer replace this for free, even though technically it is out of warranty, LG will cover the repair. (servicer may need an authorization code to get credit from LG)
Mar 16, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
The light has not been turning off which melted the plastic covering over the light bulbs and its not hanging by a wire and the light still on. the censers on the door do not turn it off anymore i...
Karri,
I experienced the same problem with my LG refrigerator (model LFC25760ST). Came home from a weekend trip only to find that the light bulb assembly had melted and dropped onto the top shelf. The interior of the refirgerator compartment was very warm (est. 70 to 80 degrees) and everything in it had spoiled. Fortunately, nothing worse had happened. (According to consumer information on the Internet this LG refrigerator is suspected - but not proven - to have been the cause of a couple of house fires.)
There was no recall, however, because the reports to the Consumer Products Safety Commission were for less than 5% of this model sold in the U.S. But if you contact LG customer service (1-800-243-0000) whether your unit is still under warranty or not they should send someone out to replace the lamp assembly at no charge to you - this one with a heat sensor that serves as a backup to turning the lights off once the doors are closed.
Newer LG refrigerators have LED lights instead of incandescent light bulbs so they don't produce enough heat to warm the interior of the fridge or melt the light housing.
To learn more about other folk's similar experiences with these LG refrigerators just do an Internet search using "LG and "LCF25760" and "melted plastic." (Note: Leave the other letters after the five numbers in the model number off - they only refer to the exterior finish [i.e., "ST" = stainless steel] and unnecessarily narrow the search so as to miss some links.
Good luck with LG customer service.
grm
Feb 15, 2011 | LG LRFD25850 French Door Refrigerator
I now have the same problem: I HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT COVER INSIDE THE FRIDGE MELTED DUE TO THE LIGHTS STAYING ON WHEN THE DOORS CLOSE. THERE ARE BUTTONS ON THE INSIDE UPPER DOOR...
LG has issued a service bulletin about this problem. You need to call LG or the ratailer you bought it from and tell them what's going on...the entire cost of the repair (parts and labor) should be covered....at least it was the last time I did one for a customer.
Oct 04, 2010 | LG 22 Cu. Ft. French Door Refrigerator,...
Error code er 55? I am not getting water into ice
There are several issues with this ref.
Ref. Lamp cover melting.
Department of energy rework.
Contact LG for service repairs are free.
Jan 04, 2010 | LG LFX25960ST Stainless Steel French Door...
Interior bulb heating up
LG has had an issue with this and has re designed the lamp cover and the lamp holder itself. contact your nearest parts supplier with your model and re order this part and you will receive the new upgraded cover.
Oct 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Original lamps producing excessive heat.
there is a recall for that problem you need to contact LG and they will send a repair kit for your refrig. it should be repaired at no cost but be sure to ask them.
Jan 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Fridge Area Light Will Not Turn Off
Yes unit was built by LG. The light broplrm is most likely the motherboard along with the light socket assembly that would have to be rreplaced. There is service information that the repair should be cover by an extened warranttee from the manufscture. The service flash sf46-515 indicates this and was recently put out. call Sears for service. Please note: recheck your model number as the one covered in the service info ends in the number :"one" insted of a "0"
Sep 02, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Picture problem after changing highe presure lamp
this is the light engine problem. i was able to get mine fixed through LG because its a known issue. this is not a bulb problem.
Feb 14, 2008 | LG RU-60SZ30 60" Rear Projection...
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
