Question about HP Compaq d530 CMT PC Desktop
5 beeps my hp compaq d530 cmt wont start up. as i switch it on, it would beep 5 times then pauses for a while, then beeps 5 times more and so on. pls help
  • 1 more comment
  • skokurt Aug 09, 2008
    the problem started after a normal operation the night before. tried removing and re inserting each component of the mother board, including the ram chips. i'll try to remove and re insert the ram chips though. but if this does not woork, does it mean my ram chips are bad?thanks randy v.
  • annieg33 Jan 05, 2009
    I hav recently moved and my HP Compaq d530 took a knock, i have just set it up and when turning it on it sounds 5 beeps, pauses then repeats. Could something have come loose or this a major problem?
  • talkingg2den Jan 25, 2009
    my hp has got 5beeps then a pause n it cannot start it happened after a well night operation
    Sergeant:
    Champion:
  • 236 Answers
Do you have the RAM chips installed in the right socket, and the right way?
Posted on Aug 09, 2008
  • Randy Villalobos
    Randy Villalobos Aug 09, 2008
    Not exactly.
    It could also mean
Beeps 5 times on start up
Try this, turn off PC. Remove memory sticks. Power pc on without sticks. Power PC off. reinsert memory sticks. power back on.
Jan 25, 2014 | HP Compaq d530 CMT PC Desktop
I have compaq 530 tower which when I switch on gives 5 short beeps, I have checked the connections as advised and they seem ok, looking on net it says 5 short beeps could be prob with CPU, what is CPU.
5 Short Beeps
Your motherboard is complaining. Try re-seating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
Apr 23, 2011 | HP Compaq d530 CMT PC Desktop
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
HP d530 cmt 2 short 1 long beep. No POST is displayed
You must be using a USB keyboard. I suggest switch back to PS2 keyboard. Moreover, the system board supports dual channel so you should be using matched pairs plus placing them in the correct slots to enable dual channel mode.
Try this and it should work without any trouble.
Regards,
Anirban Mazumdar
Mar 16, 2011 | HP Compaq d530 CMT PC Desktop
I WANT TO DOWNLOAD HP COMPAQ D530 CMT
you can easily download the setup from the following sites
forums11.itrc.hp.com/service/forums/questionanswer.do?threadId
h18000.www1.hp.com/products/quickspecs/11632.../1163
h30499.www3.hp.com/t5/...PCs...HP-d530-CM
ptf.com/vga/vga+hp+compaq+d530+cmt
www.topshareware.com/...hp-compaq-d530-cmt.../downloads
www.user-guides.co.uk/download/hp/hpcompaq/hp-compaq-d530-cmt-manual-placa-
download and install it on your device,it will work just be fine
Jan 14, 2011 | HP Compaq d530 CMT PC Desktop
Beeps on startup, no signal to monitor
Hello Dear,
We need to check the Beep Counting, If its continuosly then it seems there is some issues with Keyboard. maximum times it happend because of Memory. You Just open the Cabinet and try to change the Memory slot. Hope it will resolve. If not then Remove one RAM Stick (If there are Two) and check if its working if not then try to connect the second one and remove this one.
Hope this will help!
With regards
FIX YA team
Oct 10, 2010 | HP Compaq d530 CMT PC Desktop
Computer will not start
It all depends how many beeps there were.
From http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
I have only really come across 4 beeps = order new Power Supply or 5 Beeps = reseat the memory and hope it works
Regards,
Oli
Apr 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS.
4 beeps & 4 flashes mean problem with the power supply. For my experience, most of the time the PSU is good, it is just overloaded.
For more LED and Beep messages, check this link:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00067072/c00067072.pdf
Dec 26, 2008 | HP Compaq d530 PC Desktop
5 beeps HP Compaq d530
5 Beeps
CPU or motherboard problem
Apr 11, 2008 | HP Compaq Business d530 Ultra-Slim PC...
HP Compaq d530
it all depends on the number of flashes , pause, repeat.
Since the problem did not indicate any beeps her is the following info
Power LED blinks RED 2 times, one every second, followed by a
2-second pause. = Processor Thermal Protection Activated
3 blinks 1 second apart = Processor not installed (not an indicator for a bad processor).
4 blinks 1 second apart .= Power Failure (power supply is overloaded)
Other possibilities are:
5 blinks 1 second apart No memory
6 blinks 1 second apart No graphics
7 blinks 1 second apart System board failure (detected prior to video)
8 blinks 1 second apart Invalid ROM
Nov 07, 2007 | HP Compaq Business d530 Ultra-Slim PC...
HP Compaq d530 CMT PC Desktop Logo
1,529 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
