Question about Sansui DTV1900 TV
Out of focus
I have a brand new DTV1900. I plugged it in, and I have a screen that is white/light gray. If I push the volume button, I can just barely see it move across the bottom of the screen. It's so out of focus, that I can't tell what anything is when I push the menu button. The volume works fine though. Any ideas?
How can i unlock my tv (sharp) ; doen't turn on, all you see is the red light on when you press any botton
Posted on Aug 09, 2008
How do I turn up the volume control IPhone 3GS?
when you hold the Iphone in your hand with the round button with the square inside it on the bottom of the phone. turn the right side of the phone down to the floor while you do this look for 3 buttons on the side of the phone the TOP button must be pushed upwards at all times this flip switch is your MUTE switch pushed down it is in must mode switched up is sound mode.
Below this is 2 buttons the button just under the top flip switch is volume up the other one is volume down there ya go.
Please rate my solution and leave testimonial this is how i earn my achievements thanks in advance.
Apr 22, 2012 | Apple Cell Phones
Brand new TV, spotty HDMI functionality (sometimes recognizes cable box or comupter, but not always). Attempted firmware update on a Sharp Aquos LC-32SH7E (European model). Don't think it ever...
Did you go through the entire factory reset? When you plugged in the power cord did you continue to hold the volume - and input button until the television powered on and a K appeared on the screen never releasing at all?
Force the tv on by holding down channel down and volume + on the tv while plugging the tv in. See if the tv still lights up and if you get audio.
Jul 28, 2010 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
Connection/wiring dagram ford radio FCT006A2
2007 Ford Focus Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Oct 06, 2009 | CIBA Vision Ford Focus 2007 Stereo/radio...
TV FLASHES DIFFRENT COLOURS
The set could be in a demo mode.Wich brand is the set?
Jul 20, 2009 | Televison & Video
Ford focus 1999
Pin --- Color --- Stripe --- Function
Harness 1
1 --- White --- Black --- Left front +
2 --- Gray --- Black --- Left front -
3 --- White --- Purple --- Left rear +
4 --- Gray --- White --- Left rear -
5 --- White --- Red --- Right front +
6 --- Gray --- Red --- Right front -
7 --- White --- (none) --- Right rear +
8 --- Gray --- (none) --- Right rear -
Harness 2
1 --- (not used)
2 --- Black --- Green --- Radio Ground
3 --- (not used)
4 --- Orange (thin) --- Black --- Radio Illumination
5 --- Green --- Yellow --- Radio switch
6 --- Black --- Yellow --- Radio Ground
7 --- Orange (thick) --- Black --- Radio 12V
Harness 3
1 --- White --- Green --- Speed sensor
2 --- (not used)
3 --- (not used)
4 --- (not used)
5 --- (not used)
6 --- (not used)
Dec 22, 2008 | 2003 Ford Focus
Print coming out gray even with brand new HP cartridge
either it could be set in the printer properties to print in gray scale or it could be the lens of the printer that needs replacement as if the lens go weak the prints come out very light.
Dec 15, 2008 | HP LaserJet 4 plus Printer
Install a cd player
HERE YOU GO ALL WIRES U NEED PLEASE RATE ME GOOD LUCK WILL WORK GOOD!!!!!!!!
2003 Ford Focus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange/Black (Thick Wire)
Radio Switched 12V+ Wire: Yellow/Green
Radio Ground Wire: Black/Yellow and Black/Green
Radio Illumination Wire: Orange/Black (Thin Wire)
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: None
Left Front Speaker Wire (+): White/Black
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): White/Purple
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): White
Right Rear Speaker Wire (-): Gray
Aug 14, 2008 | 2003 Ford Focus
(strange) volume control icon stuck in the middle of my LCD monitor and the buttons on the front of the monitor are frozen and will not work?????
Restart the computer. Right click on the task manager > Task manager > End all the programs in Applications folder.
All the best.
Santo
Dec 17, 2007 | Acer AL1715 17" LCD Monitor
Sansui DTV1900 TV Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
