There is black hazey spots visable when the picture is of white or lighter colours..tv is lcd
  • shawnbelter Oct 12, 2008
    I also have a back hazy spot on the left side of the tv. I have a 56in Toshiba LCD rear projection (only a couple years old). It is approx mid way up (30 cm up and approx 30 cm from the edge. It does not move and I can only see it when a light picture passes over it.
SOURCE:
  • 105 Answers
SOURCE: I GET WHITE SPOTS ON MY LCD SCREEN
this is a touchy subject for sony. basically sony has increased the brightness levels for the backlights to have better color tones in thier lcd's. well the downfall of this is the white spots you are experiencing. this is not a defect, you will never get them to go away, the only thing you can do is to turn the backlight and brightness down to reduce the white spots. if you contact sony, there is a software upgrade that will help reduce this issue...
Posted on Oct 25, 2007
  • 4 Answers
SOURCE: green spot
Easy fix. I had the same green spot problem with PT-52LCX65 and I removed the front panel (no screws). In the center is a panel that has two screws. Remove them and pull the cover off. There you will find the projection bulb. Do not clean the bulb but instead the base. Use a damp cloth to wipe the dust off the black disk (the base of the projection bulb housing). Apparently the dust through static electricity may cause enough magnetism to distort your picture. Hope this helps.
JK
Posted on Dec 02, 2007
  • 10 Answers
SOURCE: green spot
Check with Panasonic. I have the same issue and was originally told that the optic board needed to be replaced ($1700). I waivered on getting it fixed and spending more than the tv is worth. So I now learned that there is a new fix for the bad optic board and Panasonic is repairing it free of charge. Repair is schedueled for next Friday (Feb 1, 08). I'll report back if it was successful. This repair involes an eprom on the optic board. Hope the sheds new light........
Posted on Jan 25, 2008
SOURCE: A small white spot on LCD screen TV
buy a new glass lens
Posted on Mar 19, 2008
jerryg50
  • 1691 Answers
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Posted on Apr 12, 2008
How do i get black n white to color
Where are the pictures coming from?
Off-air, cable, DVD, VTR, computer, etc?
Feb 13, 2015 | LG 32LD450 32 In. LCD HDTV
There is a Video problem with my Samsung LCD. The sound is clear but Colour Balance Setting is disturb. The Colour is mixing with each other. Can You tell me the procedure for My TV Setting?
Before you set up try a reset
Resetting The Picture And Sound To The Factory Settings
as far as advanced settings are concerned, set the contrast backlight and brightness so you can see the best blacks without it looking too milky, the best whites so you can discern the whites and they aren't clipped, then look at colour balance if it looks wrong when you turn the colour off.
it shouldn't be very far out in factory settings. Operation How To Change The Picture Settings On Your LCD TV LCD TV...
May 12, 2014 | Samsung LN-S2651D 26 in. LCD Television
Tiny black spot lcd
Erika, Do you mean you have a black spot on the LCD of your camera?
We call that a dead pixel. Can be black and can be white. Most LCD's sooner or later have a one or more dead pixel(s). As long as they are not in the centre of the screen you won't notice them. Even dead pixels on the camera sensor can happen. These you won't see at all, because the software does calculate what that pixel would look like in that specific shot. And the software will place a correct colour on that spot.
Try to live with the dead pixel(s). you won't see them on the actual pictures. Not on the computer to tablet and not on a print.
Dec 30, 2013 | GE Cameras
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
Vertical bars both sides of screen visable with white background
do thy get lighter going from left to right? prob bad scan filter in hv. need tech unless your very handy.
Dec 05, 2008 | Sony KP-53HS10 TV
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Lg 32lc2r, only showing picture in black and white
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Lcd tv picture wavy, black and white
by calling the tech they will answer your problem they will verify the problem in your colour circuit, the colour crystal or other related circuit could be your problem,the tech will give you the answer.good luck.
Apr 01, 2007 | Dell W2600 26 in. LCD Television
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Ekse
