Question about Behringer FBQ6200 Home Equalizer
Behringer FBQ1502 How can I connetc mg Ultragraph PRO FBQ1502 to my HARMAN/KARDON AVR 146?
  • jppalma62 Aug 13, 2008
    it is not helpful i still cannot connect my FBQ1502 ULTRAGRAPH to my HARMAN KARDON AVR146!!!! you gave me the wrong info because the one that you gave was about the FBQ6200!!!!
  • jppalma62 Aug 14, 2008
    ok i'll try it agian. thank you very much!
    Brigadier General:
  • 6,966 Answers
An old trick we use to do is use the TAPE IN/OUT of the receiver and hook it to the stereo RCA IN/OUT of the equalizer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 09, 2008
  • Louie  Role
    Louie Role Aug 09, 2008
    That should be "RCA type TAPE IN/OUT connectors of the receiver and hook it to the 1/4 Unbalanced TS connector for IN/OUT of the equalizer."
  • Louie  Role
    Louie Role Aug 13, 2008
    Hi again,
    Thank you for correcting the model. To my understanding the FBQ1502 also uses ¼” TRS connectors same as the FBQ6200.
Harman Kardon 146 receiver not turning on.
Possible blown fuse inside unit, unplug and remove the top cover
fuse should be near the power board and transformer. replace with exact fuse, "Never remove covers with the unit plugged in" Always wait 4 or 5 minutes after unplugging to remove the cover.Replace cover before plugging unit back in.
Oct 06, 2014 | Harmon Kardon Harman Kardon Avr 146 5.1...
I want to set up my behringer fbq1502
It sounds as if you are not running in series. I assume you are in an insert on the mic channel. The insert send should go to the first item in the chain, then from the output of that to the input on the next item and so on until the output of the final item in the chain goes back to the return on the insert. This is applicable to the type of equipment you have detailed, in some cases however you may be running effects in parallel. Your case is definitely a series situation.
Mar 08, 2014 | Behringer FBQ1502 Ultragraph Pro Dual...
How to hook up a mixer, pre amp, power amp, crossover and equalizer
let see you want me to teach you what it took me 20 years to learn in a few moments...really
Mar 06, 2014 | Behringer Ultragraph Pro Fbq1502 Feedback...
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
Circuit diagram for ultragraph pro fbq 1502
and you are skilled at large scale smt replacements..
Feb 18, 2013 | Behringer Fbq1502 Ultragraph Fbq Pro 15...
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Dec 05, 2008 | Harman Kardon AVR 130 Receiver
Hi...
Hi again,
Aug 12, 2008 | Audio Players & Recorders
Behringer FBQ6200 Home Equalizer Logo
310 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
