Question about Mustek Be@rPaw 1200CS Flatbed Scanner
Copy to cumputer
Negative's come through clear in coping when transfered to computer .
انا عاوز انزل تعريف سكنر ده
Posted on Aug 09, 2008
Sony cybershot n50
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Apr 26, 2014 | Cameras
It has been only 3 months since i bought my transcend portable 500 GB.up until now everything was fine.but now i'm facing some problems with coping files.when i copy files from external to internal...
Try to defrag you external hard drive, cek your hard drive wether there a bad ?
sometimes bad cluster can running slow for copying your data or else.sorry my english is poor.thank anyway
Jun 25, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Aiptek camera transfer to cumputer
Using the PC Camera Function
1. Installing the AF Cam driver
You need to install the AF Cam driver before using PC Camera
or video conferencing function.
* If you have already installed the AF Cam driver, skip step 1. "Installing the AF Cam driver" and go to step 2. "Connecting your camera to your computer".
2. Connecting your camera to your computer
2.1 Turn on your computer
2.3 Insert the USB cable to the USB port on your computer
2.4 Insert the other end of the USB cable to the USB port on your camera.
* Then you can see the camera as removable disk. You can transfer the pictures from your camera to your computer like transfering files from one folder to another.
1. Go to camera folder
2. Select the file/pictures you want to transfer then right click and choose move option (if you want the files to be moved on your computer) then choose the desired target folder or drive.
*you can just copy the files form the camera to your computer too.
select the files that you want to copy then right click, choose copy then paste on the desired folder or drive.
Apr 09, 2010 | Aiptek PocketCam 3M Digital Camera
Copier not coping due to teo messages on the display, 020 and C-6
Hello sir; your machine temperatur too high need to reset the procedur as follow;
1, press "stop/clear" key, "start" key", and left copy density key.
2, press "stop/clear" key again.
3, enter U163 press "start".
4, when screen display "CLE" then press "start" again to reset.
May 29, 2009 | Kyocera Office Equipment & Supplies
Samsung l83t
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 07, 2009 | Samsung Digimax L830 Digital Camera
Transfering address book and Favorite Center fom one computer - -
Your Favorites are stored in Cocuments ans Settings folder under your name and in the Favorites folder.
Eg. C:\Documents and Sttings\"your name"\Favorites
Copy the Favorites folder to a USB memory stick and then copy it to your 2nd computer in the C:\Documents and Sttings\"your name" folder - exactly as per your Toshiba.
To transfer your e-mail address book from one computer -
1. Open Outlook on your Toshiba, then click on File, then Export, then Address Book - save this file (remember the file name and the location where you saved this file.
2. Copy this file to a USB memory stick.
3. Open Outlook on the Gateway computer.
4. Then click in File, then Import, then Address Book, then to the USB memory stick (could be your E: drive) where the exported address book file is located.
A copy of the address book is now in your Gatway computer.
Jan 17, 2009 | Computers & Internet
Copying pictures from computer to memory card
vista is main problem are you viewing the picture before you move them vista has problem if u open it 1st before coping moving etc etc it does what u mentiond b4 either shut the program u are using to view with down before u transfer them
Dec 02, 2008 | Cameras
Dark strip
LIFT THE COVER UP AND CHECK FOR A SOMETHING ON THE NARROW GLASS IN FRONT OF WHERE THE FLAT BED SCANNER SCANS .
COULD BE WHITEOUT OR GREASE MARKER OR EVEN A DIRTY PEACE OF PAPER
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Transfer pictures to computer
Apr 10, 2008 | Samsung Digimax S800 Digital Camera
Transfering numbers and deleting them
please copy your phone to computer first
and then to your next phone
hope it works
for more information
you can mail me
raj_the_great2008@yahoo.com
thanks
Mar 21, 2008 | LG CU500 Cellular Phone
Mustek Be@rPaw 1200CS Flatbed Scanner Logo
182 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Tony
Mike
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
