Question about Siemens S40 Cellular Phone
Siemens cx75 Hi I tried to reset my phone to factory default but it never fixed the problem. The joy stick and power key doesnt work properly and it keep browsing even when im not pressing anything, there was a time that it keeps sending message with out touching anything . I believe it is as software problem. Any other solution? thanks!
SOURCE:
  • 13434 Answers
SOURCE: Siemens Sx66 Pda phone- not responding for hard reset-
Hello, Did my solution fix your SX66 problem?
Posted on Jun 25, 2008
SOURCE: Siemens Phone
Some dude on ebay a while back specialized in fixing this pblm w a guarantee, i think the price was around $75, a little steep for what the phone is worth. You may want to browse some of the shops that come up in response to searching on "siemens 2420" as I forgot the guy's name...
Posted on Aug 02, 2008
  • 750 Answers
SOURCE: siemens SE25A266GB/22
Hello
Welcome.
You said, Hi My dishwasher programmer doesnt work, when i try to put the time in it will not let me go further thah 20 minutes or so, then if you run that time it sticks on 'one minute to go'. on opening nothing has been cleaned.
Need the model number and the year.
Try to turn off the machine and then turn off the breaker for five minutes and see if it resets the system.
Sounds like :
Defective Timer
The timer is a series of switches that controls all machine functions. If one of the contacts in the timer is defective, the machine will lose that function. knowledge of the the use of a vol/ohmmeter is essential to testing the timer as well as the ability to read the timer sequence chart that is supplied with the machine. In most cases this requires a professional technician.
Let me know how it goes.
Huuum
Please remember to leave a rating!
Posted on Oct 22, 2008
SOURCE: The drain pump keeps running when the machine is
This sounds like its gone into flood mode.
If water is detected in the base of the machine, the pump switches on and stays on to prevent flooding.
Normally to reset you would lean the machine backwards and let the water drain out.
In your case, switch off the mains, remove the lower kick panel. Shine a torch in there and you should see the water. CAREFULLY dry it out and it should reset.
If it does it again, you need to check for leaks.
Posted on Apr 02, 2010
Testimonial: "Excellent, I did as you said and it worked a treat. Many Thanks."
rhinoking1
  • 85 Answers
SOURCE: Siemens 5890 DSL Router/Modem Need factory reset.
Most routers have a defalt user/password for setup and chainges. Try "admin" "password" to gain access to router. From there you should be able to reset any passwords put on it.
Posted on Jul 06, 2010
I have done a factory reset on this phone and it still requires a passcode
If you have done a proper factory reset and not a soft reset! Then the default code is 1234! If this does not work then you have not done a factory reset!
Dec 06, 2014 | Cell Phones
Tip
Master Reset, Format and Unlock Phone Code Siemens SX1
Warning : This will erase your user data from phone like phone book and messages.
  • Get battery out of your phone and insert back in.
  • now press * and # keys at same time
  • while keeping pressed * and # keys now press power on button.
  • You will see phone says formatting after it your code is gone and phone is in its factory default settings.
on May 13, 2010 | Siemens SX1
My siemens cx75 is telling me internet service is not enable, how can i enable it
you need to activate the DATA service through your mobile operator. Pls call them and check with them if your contract includes DATA as well.
If it includes data, then you need to made 2 modifications in your phone setup. If not, check the prices for that and activate them from your provider.
I have attached the phone manual for your convenience as well:
- Setup a profile for the internet access. This profile (ceck manual page 39) must be setup up according to your provider's instructions so pls call the provider and ask him to provide these settings. Usually, they send to your phone an automated message that has all the needed settings (data profile settings) and you just run it.
- Activate GPRS. Go to Settings -> connectivity and activate GPRS. (page 46 of the manual).
http://www.sendspace.com/file/wq5tqp
Aug 08, 2011 | Siemens CX75
I have a Pocket PC, Fujitsu Siemens N520. Tried to hard reset it and now it's stuck at the climbing people image. Tried everythinh i knew. hard reset, soft reset, battery out for 5 mins. Nothing. Please...
Fujitsu Siemens have a tech online contact point where you can advise them of the problem. The Hard Reset has always worked for me - do you get the option of "Factory Default" show - if not then you have not done the hard reset properly. Depress Enter and use the stylus to press the reset button in the rear. Good luck
Aug 11, 2009 | Fujitsu Siemens Computers & Internet
Unlocking a siemens cl75 from virgin network for free with code online
You can easily unlock your mobile using the code. If you need an unlocking code, simply get it from http://www.mobile-unlocker.com/siemens-cl75/rs2wp9/ .Here i found the valid unlocking codes. You can easily unlock your mobile using this.
Feb 17, 2009 | Personal Handsfree for Siemens CL75 Poppy...
My siemens 4010 cordless phone is saying "Base Search" recently
"Base Search" will display for several reasons.
  1. The base station is turned off or not working properly.
  2. The handset is not registered.
  3. The handset may be registered somewhere else, de-register it.
  4. The units (both base and handset/s) may need to be reset to factory default.
You may have already tried this.
Jan 15, 2009 | Siemens Gigaset 4010 Cordless Phone
System pin # reset
There is a way to override and reset... I think you need to press *67# when in the system pin area via menu. Confirm this first though. There is a way to do this though- then you reset it to 0000- google it and you will find the answer-
Dec 01, 2008 | Siemens Gigaset 2420 Phone
Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Nov 14, 2007 | Siemens Gigaset 2420 Phone
Phone has chinese text!
hi maam,
try resetting your mobile phone to its factory settings. you can access this menu to your mobile phone setting menu...
try it..
Oct 13, 2007 | Siemens M55
Siemens S40 Cellular Phone Logo
132 people viewed this question
Top Siemens Cell Phones Experts
Ekse
Trimesh
Colin Stickland
Colin Stickland
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
