Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
How do you unclog the hose to a whirlpool gold dishwasher? It overflows into my sink. I have checked the hose and there doesn't appear to be a clog.
  • haveaheart67 Aug 09, 2008
    It is not hooked to the GD so I will try the boiling water. I will let you know if it works. Thank you for your suggestion.
  • bertie byrne Feb 17, 2009
    When the water drains from my Maytag Jetclean dishwasher it comes out of the overflow next to the faucet. Why is it doing that
  • 5 Answers
I had this same problem and solved it. The black rubber hose leading from my Disposal to the overflow vent on the sink corner was clogged. You will need to remove the hose via 2 hose clamps and scrape out the nasty gunk inside. Did I say Nasty???? I meant NASTY! I used a straight piece of 1/2" conduit to scrape the inside walls and then pushed a piece of rag through it again and again till it was clean. Don't forget to check the disposal nipple which leads into the grinding chamber. That thing was nastily clogged on mine. Had to use a knife or something (I don't recal) to scrape out the walls of this 2-3" deep opening. Works like a charm now.
I'll save you some trouble.....I took apart the vent and the dishwasher hose all for not! They were clean as a whistle. It was that dang disposal cauding all the problems.
Good luck! Hope this helps!
Greg
Posted on Mar 12, 2009
    Novelist:
  • 158 Answers
Does the hose go directly to the drainpipe, or is it attached to the garbage disposer? If it is attached to the garbage disposer, the disposer itself may be plugged. Try operating the disposer with some soft food in it, and see if it grinds up and drains away the food. You can remove the hose from the disposer to check for a clog. If the hose is atttached directly to your drainpipe, the drainpipe may be clogged. Try pouring a large pot of boiling water down the drain to free up the clog.
Posted on Aug 09, 2008
My dishwasher says DE and does not empty the water after the wash cycle ????
Most commonly, this is due to as clogged dishwasher drain hose. If you have had agarbage disposal installed, it can also be due to the dishwasher plug not having been removed from the disposal. This can be done with a screwdriver (just make sure to remove the plastic plug from the disposal). These will most commonly run from underneath your dishwasher to your garbage disposal (or to a drain pipe under sink). Many times they can be unclogged by removing the hose from under the sink and using a wet/dry vacuum (with the filter removed, so it can suck up wet stuff) to auction the end of the hose. If the hose is not clogged, the vacuum will suck the water through the hose and our if the dishwasher. If it is clogged, hopefully, the vacuum will suck pour the clog, and then suck the water from the sink.
Hope this helps
Oct 31, 2013 | Whirlpool ADG450 Slim-Line Built-in...
Constipation
Can you check the exhaust water hose by looking straight down the drain in the sink where a dishwasher exhaust hose is normally attached, to see if you have any water leaving the dishwasher at all? Can you remove the exhaust hose, and put in a pan to see if you can get some water to flow out? I am guessing you may have a clogged exhaust hose, or clogged sink attachment on the sink drain. After lot of use, debrea will build up in the exhaust hose. You might also consider cleaning the inlet valve filter, the collect sand from the water supply, and can clog after many year of service.
Dec 19, 2012 | Whirlpool Dishwashers
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Dishwasher is not draining. how do you unclog? Removed all screens and traps, can't figure out where the clog is?
Those models commonly get food stuck in the spray arms. I would suggest you disassemble one or both and check for clogs there.
If you've checked all the screens and traps (and spray arms) in the dishwasher, have you checked the water flow in the hose to the sink and at the air gap (the small metal cylinder that sits on many sinks)? A dishwasher is typically connected to the air gap, then a short tube goes down and connects to the garbage disposal (if one is installed). The hose running from the dishwasher to the sink can become clogged as well. An easy way to check it is to tap the hose or pick it up close to the dishwasher. If it sounds full or is heavy, you've probably got a clog in the hose. If you do, be careful when you go to clear it, because the hose is full of water.
Feb 28, 2011 | Frigidaire 24 in. FDB635RF Built-in...
I have a whirlpool gold and there is water in the bottom after the cycle. i cleaned everything out and didn't see any blockage.
the drain hose maybe clogged it connects to the garbage disposal or the air gap at under the sink. you can get a wet dry vac and **** it out . or if the hose is just laying under the sink on the bottom of the cabinet you need a loop put in it. just attach it to the top of the sink some where and leave slack after the attached location toward the sink.
Nov 17, 2010 | Whirlpool DU930 Built-in Dishwasher
Dishwasher Leaking From Overflow Valve at Sink
think you've already figured it out! clog could be in dw hose where it enters gd. check for kinks in hose. perhaps replace hose, if it looks funky! try running a sterilize cycle- the hot water may unclog the hose (if your machine has the option).
good luck!
Apr 17, 2010 | Kenmore Elite 45986 Front Load Washer
I have a whirlpool gold model GU1500 diswasher. When the rinse cycle ends the water pumps out into the garbage disposal like it should, but then water backs-up from somewhere into the bottom of the...
Seems you answered your own question here. You need to make an air gap in the drain hose - take as much slack as possible and make a curve (upside down U) under you sink as high as you can go. Make sure you clip ot to back of the cabinet to stabilize it. Good luck
Jan 11, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Overflow draining to the sink
it's supposed to drain out the same drain pipe your sink uses. If it is overflowing into your sink, then your drain pipe is clogged. Your sink probably overflows when your disposal runs too, right? Unclog your pipe and you're good to go.
Jan 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water shoots out of the water diverter or overflow on the sink but its not cloged
Yoou must be talking about the air gap for dishwasher discharge hose. This will show water if the inlet to the disposal is clogged and the water has a hard time getting through the inlet (it is a common problem). The problem is not with the dishwasher, Disconnect the rubber hose end to this outlet and check the inlet piece and check the hose that you just removed; you should see something clogged. Goodluck ,Macgivor.
Nov 20, 2009 | Whirlpool Dishwashers
Dishwasher does not drain, instead drains through overflow valve in sink. No apparent clog seen.
Usually the sink connection is not an overflow, it is the main drain from the dishwasher. It is more likely your s-bend is blocked under the sink- try putting a bucket under it and unscrewing the u-shaped piece and cleaning out (remember don't wash it in that sink while the pipe is off)
Apr 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
1,014 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
