Question about LaCie (301144) 120 GB USB 2.0 Hard Drive
LaCie is not booting up on the computer
After some power outage my LaCie drive is no longer working with my eMac.
It is not recognized even when switched on with proper connection
  • LaCie Master
  • 3,051 Answers
Go to my computer and right click then go to properties under device manager look for the device and right clik on it and look sor something that says remove device and say yes it will ask you to comfirm removal press yes again than after it tells you it has been uninstlled restart the computer make sure the device is turned on once the computer starts back up a found new hardware should pop up on the taskbar and should finish reinstalling drivers for the device and hopefully this should take care of that problem ok let me know ok good luck !!!
Posted on Aug 09, 2008
I have 2 lacie external hard drives that no longer work. They power up and I can hear it working, but they are not reconized on any computer.
Chances are, the IDE/SATA to USB/Firewire controller inside the device has died. You can take the case apart and take the hard drive out, and plug it directly into a computer through IDE or SATA, whichever it is. If the drive is recognized, then all you need is another external case to put the drive into. If it isn't recognized then most likely the powerboard on the hard drive or some other internal mechanical part is dead, and you would need professional data recovery to get anything off of it that you would want.
Apr 30, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Dead hard drive
Try unplugging the usb connector and plugging it back in. Your pc shouls recognize the installed component automatically. Also, some external hard drives work like normal pc's do: hold the power button in longer until something happens. Hope this helps.
May 24, 2009 | LaCie (300770) 250 GB Hard Drive
Machine not recognized by computer it just is makign a clicking noise
i got the same problem. let me know if you figure it out. except mine stoped making the noise eventually, but still wont recognize.
May 23, 2009 | LaCie Computers & Internet
Lacie 500gb quadra external drive won't boot using USB cables.
Microsoft has had some issues in regard to external devices (especially after running some updates). There is a registry patch for this situation. Click below to install the patch. It should fix your external drive problem. All the best!
Greg
http://support.microsoft.com/kb/925196#fixit4me
May 19, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
MAC G4 won't boot - Blue screen appears
Hi Sorry to hear you are having troubles,You will need a firewire 400 cableOK, first thing you must do is reboot the eMac in TARGET mode, this means it will be recognized as an external disk. To get the eMac in TARGET mode, you must be sure the eMac is turned OFF and has a functioning keyboard connected.Power on the eMac and very very rapidly press the ( T ) key on the keyboard, be sure the caps lock button is not pressed. If all goes well, you will see the firewire logo appear larger than life on the screen.( If you are unable to get into TARGET mode, it is highly probable that the mother board of the internal hard drive is damaged and preventing the eMac from entering TARGET mode, sorry, that's the end of the line..)Once you enter TARGET mode on the eMac, connect the firewire cable to your G4 PowerBook, you can do this either while it is running or when it is off and then turn it on.
You should see the volume of your eMac internal hard drive appear on the PowerBook desktop...sometimes you need to open Disk Utilities and repair or mount the drive manually.If this all works well, copy the required files directly to your PowerBook...After that, power off both machines, disconnect them and reboot the eMac using a CD or DVD to reformat and reinstall a new system.
Mar 30, 2009 | Apple eMac G4 Desktop
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie Hard drive not recognized
If your computer recognized the hard drive before you have installed your last operating sistem(s) that can be the problem. Your operating sistem or BIOS is not seeing your hard drive any more. Installing a new operating sistem is going to solve your problem but try another one, not the operating sistem you used until now.
Dec 26, 2008 | Computers & Internet
External hard drive
I just worked through this same issue with LaCie tech support and they fixed it- it was a bad power supply. Fortunately I had another LaCie drive and when I plugged the power supply from that one in to the "misbehaving" drive, everything booted up fine.
Sep 20, 2008 | LaCie (300770) 250 GB Hard Drive
Can't access my lacie external hard drive
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Jan 09, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie (301144) 120 GB USB 2.0 Hard Drive Logo
114 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
