Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washing mashine.. plugged in but lights on front won't come on
Plugged in .... and was working fine... now plugged in and it's like there is no power and lights on front won't come on... checked and even reset breaker.. still no power. (lights won't come on and won't function).
is there a fuse inside the machine???
please help!!!!.... before i rip the machine apart
  • diamond6 Aug 11, 2008
    was working fine. won't turn on when button is pulled out. checked door, breaker, extension to another room, drum spins when manually turned. No light. Less than six years old, used mild HE detergents,etc.
  • 876 Answers
Go to www.frigidaire.com
>Customer Service
>Product manuals>your model number
>right click to download tech data, (which will give a repairmans info )and any other manuals you think you might need.
These are in PDF format. so if you don;t have adobe acrobat, you need to go to www.adobe.com/acrobat and download the free software so you can read the manuals. Once you have the manuals you can click on the little icon which is a stack of pages on the left column to go through the infomation,. Good Luck.
Posted on Aug 13, 2008
SOURCE:
Spin cycle does not get water out of clothes
check your drain, remover front or back panel, look for drain plug... it may be plugged. I have a Kenmore Front Load and did it last night. It is working fine now. There was alot on change and junk in it.
Denise
Dec 17, 2010 | Frigidaire ATF6000ES Front Load Washer
From time to time the mashine is not evacuate the water and the mashine will not start for a new load .I have to unscrew the filter,drain the water and then will wash. Is a problem with the pump? thank you...
a front loader huh, usually there is an access panel at the bottom front held on with 2 screws. remove this panel and trhere should be a trap filter that is plugged up. remove filter and clean it out, than put it back. or the water pump is going bad try the filter first.
Nov 07, 2009 | Whirlpool LHW0050PQ Front Load Washer
My frigidaire front loader just stopped working... all of the lights went out, now nothing works
First off make sure your plug is getting electricity from its source, very seldom a washer stops working "completely".
If the breaker is fine and you are getting electricity to the board then chances are your main board is burnt www.laundryroomadvice.com
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
How to use
http://www.frigidaire.com/support/support.asp you can download an operaters manuel here hope it helps
Jan 15, 2008 | Electrolux EW1000i Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
187 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
