Question about Brother HL-2040 Laser Printer
Green ready light on, but will not print
Brother HL-2040 will not print. After refilling the paper supply, my printer stopped printing. Has just the standard green ready light ( which blinks as I send a print job). Nothing from a print test (turn on with GO button depressed, release and depress once.). (Any way to do a NVRAM reset on this ******? Never any problems until now.) We are still on the initial toner cartridge, I hesitate to buy and try a new one if this isn't going to make any difference. Thanks for any ideas...
(I have looked and covering the toner light beam path,
the low toner, front door open, hold go, turn on, release, two "GOes" then three "GOes",
and even giving it the evil eye!)
  • Will83706 Nov 12, 2008
    I have a brother HL 2040 printer and it seems all of a sudden it stopped printing. The system tray says 0 jobs pending and then forgets that I even tried to print. Printer in control panel has ready status and seems recognized. Also printer works fine off of my linux laptop. This is a vista machine and it does not.
    Novelist:
  • 158 Answers
When you refilled the paper, did you load a different size paper? Try this: on your PC, left click on START, then left click on CONTROL PANEL. Next, left click on PRINTERS. Find your BROTHER on the printers page and view the status box. Does it show READY? Are there any DOCUMENTS pending? Left click (you may have to click twice)on the BROTHER icon. The PRINT QUEUE appear, showing any documents waiting to be printed, and their status. If anything is in the queue, cancel all documents so the queue is clear. Next, RIGHT CLICK on the BROTHER icon . On the drop down menu,left click on PRINTING PREFERENCES. Make sure the settings match the paper you have loaded in your machine. If something is not right (Paper size, orientation,etc) the machine will not print. Carefully check all the settings and correct as necessary. To test, first click OK to exit PRINTING PREFERENCES. On the same menu, left click on PROPERTIES. On the GENERAL tab, left click on TEST PAGE button to generate a test print.
Posted on Aug 12, 2008
Why won't it print?
Brother HL 2040 Laser Printer Repair solution - YouTube
? 2:25
www.youtube.com/watch?v=t4GGvm3aW7c
Oct 25, 2012 - Uploaded by nobblynoel Brother HL 2040 Printer Repair solution for multiple page jams For more Info ... My Brother HL2030 laser printer is making a groaning/grinding noise on ..... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ...
Aug 07, 2015 | Brother HL-2030 Laser Printer
My brother HL-2040 wont print and the green ready light is blinking but nothing is happening
Have you tried pressing the GO button to reset the device? I had a similar problem, found this manual and it helped me, check out the troubleshooter ;) Brother HL-2240 manual
Oct 04, 2013 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
Green ready light is on but will not print
Try to hold on the Start buttom for 1 min to reset the machine.
May 26, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Wont print or only few pages
sounds like a Mpcb malfunction.(expensive now its out of warrenty) you can replace the printer with what the repair
would cost you.
Jun 11, 2008 | Brother HL-2040 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
Printer only printed 30 pages after refilling toner
Open the front cover and leave open while completing the following steps:
Turn the printer off.
Hold the 'go' button while turning the printer on. All panel lights should be on.
Release the 'go' button.
Press the 'go' button 2 times.
Pause.
Press the 'go' button 5 times.
The toner light should be off.
The paper light should be on.
Close cover. The ready light should be the only light on.
Dec 29, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
377 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
