I have a plasma tv that has lines on it and no picture. the problem started with water incedent
    Problem Solver:
  • 53 Answers
Hello Greg
You will need to have the Tv taken to a repair shop. You will have to have the Plasma Display Panel replaced.
Posted on Aug 09, 2008
SOURCE:
My panasonic plasma started showing vertical lines
Look at the buffer board or the Y sustain board on a plasma having picture aberrations.
Sep 16, 2016 | Panasonic Viera 50" Class 1080p Full HD 3D...
Horizonal line across middle of screen top half of picture perfect bottom half has small lines in picture hitachi hd S 69 plasma
I'm not sure if this model is the one that has resistors that go bad. You can actually purchase a pack of resistors in a kit. It will come with solder, the resistors and instructions. You can lay the tv out and take the circuit board out to find the blown components, and replace the bad ones. Takes about an hour start to finish and will cost around $65.00. It has been a few years since I did this, so I'm not sure on the price.
Apr 04, 2015 | Hitachi UltraVision 55HDS69 55 in. Plasma...
My 50 inch plasma tv has black lines appear in picture
The issue could just be with the signal cable. Make sure the cable is not loose. Also try replacing the cable if you have an extra. If the lines disappear it could also just be an issue with the plasma, it may get worse over time, but don't worry about it for now.
Apr 09, 2014 | LG Electronics 50PG30 50" 1080p Plasma TV...
Green tint in picture
Are the lines completely through the screen or just the upper or lower part of the screen? If through the whole picture, lines in the picture of a plasma can be caused by a defective Main Logic Control board or a bad plasma panel. The panel, if available would be very expensive (cheaper to buy a new TV). If the lines are just on the upper or lower part of the screen then it is the upper or lower scan drive board. Here is a list of the parts for your TV.
https://www.tristatemodule.com/t-Search.aspx?q=TH-42PX60U
Nov 04, 2013 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
VERTICAL LINES ON SCREEN
So it's no longer under warranty.... right? The problem you describe is control by a 'digital' driver IC (integrated circuit chip) which has apparently developed temperature problems.
Jun 30, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Wide vertical bands of color through the viewing area. The sound is fine
May 24, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Ekse
