Robert_bunto
You may have a loose connection from your TV 2 feed. You can check the cables on the back of the receiver to make sure they are secure. Depending upon your installation, you could have 1 or 2 separators back feeding your TV 2 from the receiver to your TV 2. In the center of the receiver you have your TV 2 coax port. From that TV 2 port, check all points of connections to make sure the cables are secure and tight. If this doesn't resolve the issue, you may have a bad connector or switch, which would require a technician to repair. I hope this helps.
Ray Calo
DISH Network
