Question about Whirlpool Washing Machines
Front seal on whirlpool front loader (WFS1071AW)has torn and now leaks from front where can a replacement part be sourced
Whirlpool wfs1071bw,how to replace broken control knob
Posted on Jun 30, 2010
    Genius:
  • 1,028 Answers
Ck with whirlpool dealer or sears parts..sears.com has a parts look up system allowing part lookup for all national brands
Posted on Aug 09, 2008
Washer is leaking
If your Whirlpool FRONT LOADER is leaking, the following link can give you some guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
The manufacturer recommends that you leave the washer door open between washes to prevent the seal from becoming permanently stretched. Once the seal stays compressed constantly it can stretch and not seal properly. In addition, leaving the door open helpd let the wash tub air out and prevent mold, mildew and musty odors.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Sep 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is pouring out of the bottom part of the washer door.
If your Whirlpool FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
repairclinic.com
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Jul 10, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Seal on front door is torn
If your FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
repairclinic.com
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Jul 04, 2010 | Kenmore Front Load Washer
Tiny leak at front of machine
Is this a FRONT LOADER? Or, a TOP LOADER?
The following link explains how to access and inspect the interior of a FRONT LOADER and what common sources of leaks to look for:
The most common source of front loader leaks comes from the door bellow (gray rubber seal). A routine inspection around the perimeter of the door for rips or tears will tell if the bellow needs replaced. If the bellow requires replacement, the following link explains how:
If this is a TOP LOADER, the following link explains how to access and inspect the interior for common sources of leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The most common source of leaking on a TOP LOADER is the drain pump. These pumps are not serviceable and if found to be leaking, need to be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Whatever style washer you have, make sure you read through the links provided and follow the steps on how to properly access your washer interior so you can get an accurate view. Make sure you check all tub seals, dispenser hoses and drain hoses as well.
Replacement parts (if required) can be purchased from any of the following websites:
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Jun 22, 2010 | Washing Machines
Washer is leaking from under machine checked all hoses and drain connections and there were no leaks in them.
repairclinic.com
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Jun 08, 2010 | Washing Machines
Water leak from source which cannot be seen
Is this a FRONT LOADER? Or, is this a TOP LOADER?
If this is a FRONT LOADING Kenmore washer, the following link explains how to access and inspect the washer for leaks:
In most cases, the source of the leak on a FRONT LOADER is the door bellow (gray rubber seal). If the bellow is ripped or torn it must be replaced. The following link explains how:
NOTE: Overloading a front loader can contribute to premature wear and tear on the door bellow and cause damage.
If this is a TOP LOADING Kenmore washer, the following link explains how to access and inspect for leaks:
The most common source of a leak on a TOP LOADER is a leaking drain pump. If the drain pump begins to leak, it is not serviceable and must be replaced. The following link explains how:
Read through the links provided and verify all your drain hoses and dispenser hoses as well. Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
repairclinic.com
If you have any questions, please post back with your MODEL NUMBER, so that I can determine how your washer is configured. I hope this helps you.
Mar 15, 2010 | Washing Machines
My whirlpool duet washer leaks. It is not the
The following link explains how to determine where a leak may be coming from in a Whirlpool Duet:
In many cases, the rubber bellow (door seal) is the source of the leak and will need to be replaced. If the bellow is ripped or torn the following link explains step-by-step how to replace one:
NOTE: THe bellow does wear out from time to time and will need to be replaced. However, using too much detergent, the wrong type of detergent, or loading the washer excessively can contribute to premature wear and tear and deterioration.
If you have any questions, or are having problems determining where the source of where your leak may be coming from , please post back and let me know. I hope this helps you.
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Large inside rubber seal torn for the third time
new boot or "bellow" is $116 and you could do it yourself. some older front loaders had this problem. the larger the gap opening to its lower trench the more it collects. would not recommend tranditional top loader as these are being phased out. if you must buy a new machine- recommend other than whirlpool, front load (buy GE, or LG)
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frotnt door seal ghw9150
why ? is it torn and leaking or just mildew? if not torn cleaning best bet with chlorine bleach and water.if you still want to change it remove spring front front edge pull seal back toward drum on back section big clamping band remove band pull seal off and reinstall reverse order can be a dog if not experienced good luck
Apr 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
356 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
