Question about Maytag Microwave Ovens
Maytag Microwave Model MMV1153AAW. Touch pad unresponspive. Digital readout reads all 9's. Oven light works.
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    Let us know if the hard reset does not fix it.
    (It may have a bad keypad, which we can replace for $39.95 plus part costs.)
MicrowaveSvc
  • 9098 Answers
SOURCE: LG Microwave Oven LMV2053SW
That's common - it's a problem on your control panel. We regularly repair these control panels for only $32.50 nationwide. For critical safety info & detailed disassembly info, see our link in our FixYa listing here: http://tinyurl.com/yzjozk Let me know if you need further help. I appreciate your kind rating!
Posted on Jan 28, 2007
SOURCE: Maytag MMV1153AAW microwave
I have the same problem with mine!!! I spent 58 dollars to have a 6 dollar diode replaced. Now 8 months later... same prob. Replaced again myself and working fine again. Just make sure you label the wires while working on it. I didn't and it cost me 2 new fuses! Hope this helps.
Posted on Aug 15, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Kitchen aid microwave oven not working.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave touch pad work light doesn't work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Dec 31, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: No heat from my microwave maytag mmv1153aaw
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
But if when you start to microwave, if the turntable, inside light and internal light are not on, then you instead have a bad door switch or door switch mount, in which case you should see this:
http://www.microwavedisplay.com/doorsw.txt
Posted on Feb 15, 2009
The touchpad on my microwave may tag model mmv5000b will not work, how do I fix the problem?
the control board needs to replaced for the touch pad to respond well again.
Regards.
Dec 31, 2011 | Maytag MMV5000 Microwave Oven
I self cleaned oven and at end f cycle the dor is still locked and the touch pad for the oven is not working. The microwave touch pad is working fine. I tried to rest breaker but the problem did not go...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Apr 30, 2011 | Microwave Ovens
I have a maytag microwave model # mmv1153aaw..the light and/or air vent turn on all by themselves..I hear a beep, go into the kitchen and the vent is running or the light is on. Is this a fire hazard??...
I have a MMV1153BAB. My service tech mentioned that if use of the surface units overheat the microwave, the microwave fan will come on automatically.
Nov 11, 2009 | Maytag MMV1153A Microwave Oven
Nothing on my touch pad works
My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
after a few seconds.
We brought it in July or August
Debbie
Mar 27, 2009 | Maytag MMV1153A Microwave Oven
Feb 13, 2009 | Maytag MMV1153A Microwave Oven
No power maytag mmv1153aaw
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
It may be an open fuse, magnetron TCO or oven cavity TCO.
Accessing the oven cavity for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Maytag owner's manuals and installation instructions here.
Jan 27, 2009 | Maytag MMV4205 Microwave Oven
Maytag mmv1153aaw
Aug 06, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
