The CEL light will set a history code. This code can be retrieved through the OBD II connector under the dash, near the steering column. Both Auto Zone, and Advance will read codes for you Carte blanche.
Dear
You have not mentioned the model. However you can download the SAMSUNG EASY PRINTER MANAGER which can show which door is opened. The door has a leaver which close the switch inside the printer to acknowledge the door is closed, either the lever broken or mis-aligned. You can check it with a insulated plastic knife pushing the sensor switch.
hope the above may get you some idea.
thanks.
Use the following procedure to turn off wave protect: 1. Power on while holding SETUP and WAVE ("Welcome to SPD-S",
followed by "wave protect off" will show momentarily in the display). Note: Repeat the procedure to turn wave protect back on.
The card I have always been using is now also suddenly giving this
message. I found an old SanDisk 16MB and a 1GB SanDisk that works
perfectly in my Boss 864 and they also give the same message. Trying to
go into formatting brings the message "no card!"
