Question about Microwave Ovens
Micro Wave The turn table goes around, the light works and so does the timer. It just will not heat. Tried another outlet and even tried chnaging power setting. Nothing makes it heat.
  • 1 more comment
  • mstcounty Aug 10, 2008
    GE model # JES738
  • William Miller
    William Miller May 11, 2010
    With the symptoms you mention, then the problem is likely to be in the high voltage section, either the high voltage transformer, diode, or the magnetron.
    Please reply back with your brand and model number so we can help you.
  • Anonymous Mar 30, 2014
    Micro won't set back to power mode. Stays only in timer mode
  • Microwave Ovens Master
  • 9,086 Answers
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/diode.html http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
We\'re happy to help you with free advice and we\'d appreciate your thoughtful rating of our answer.
Posted on Aug 10, 2008
GE JVM1850 turns on but turn table doesn't rotate & light doesn't come on even though timer counts down. Doesn't heat & has low hum noise. Is it worth fixing or should I buy new? It is 8 yrs old.
if you like your micro fixe it, becouse even do new micros look better when it comes to work they suck they hardly last the warranty period thats if you are lucky...
Oct 19, 2013 | GE JVM1850 1000 Watts Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
Nov 13, 2011 | GE JVM1850 1000 Watts Microwave Oven
MICRO WAVE IS NOT HEATING. Light works; table turns but not heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 14, 2010 | Hotpoint RVM1435 Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
