Question about Oster 200 Watts 2382 Hand/Stand Mixer
Oster 2382 hand mixer
I need to purchase a small plastic gear which holds the beater in place. I don't have a part #. It is a milky color plastic with small teeth on the gear and a shaft about 1 1/2 " long.  It broke and i glued it with gorilla glue and that lasted a little while, but it has broken again and I want to replace it. Do you know where I can find one? Thanks
Mary
SOURCE: mixer
i called kitchenaid. and i am repaired. lay mixer on its side. then you can see how rod needs to line up. loosten screw a bit if necessary. then tighten back up. very easy solution!
Posted on Dec 22, 2007
  • 125 Answers
SOURCE: mixer runs, but will not turn beater.
You are correct, in the mixer head above the attachment hub is a gearbox, and there is a fiber gear meant to do just that should something similar happen, it can be replaced, I don't know price, but if you are careful, and fair mechanically, it is a straight forward replacement.
Posted on Dec 30, 2008
  • 2976 Answers
SOURCE: Can not remove the beater from mixer
Will it turn at all? Try to soak it. Put a paper towel strip where the beater locks onto the shaft and soak ot with window cleaner. Let it soak for a while. If there's any buildup, this should soften it.
Posted on Jan 16, 2009
SOURCE: Oster Regency kitchen center question
I just got one from a yard sale.... Had same problem, until I figured out that I needed to depress the plastic release button. Here's how to find it: underneath the mixer, the plastic is divided into two parts, the place where you insert the beaters and the section that is closer to the hinge. From the upright position, find the section closer to the hinge and press UP. This will release the head to you can tilt it.
Posted on Aug 24, 2009
SOURCE: WHERE TO FIND REPLACEMENT BEATERS FOR OSTER 2532
NEED BEATERS FOR OSTER 2532 HAND MIXER
Posted on Jan 30, 2011
Can I get parts hot kitchen aid hand mixer model khm7twh beater won’t stay in because plastic tabs are broken that hold the beater in
Hello, Joe -
From a post on a YouTube video demonstrating a McGyver-type fix to a damaged beater ring (the plastic piece which holds a beater in place) apparently KitchenAid has discontinued the availability of the beather ring.
This is the link to the YouTube video with the McGyver-type repair demonstrated:
https://www.youtube.com/watch?v=CmS4FbROS50
The comment about the discontinued beater ring is from Dan Peters.
See the information here from KitchenAid:
http://producthelp.kitchenaid.com/Countertop_Appliances/Hand_Mixers/Hand_Mixer_Assembly_and_Operation/Beaters_fall_out
If you decide not to try the McGyver-type repair and choose to purchase a new hand mixer, you may wish to put the old mixer up for sale, to be used for repair parts (since it still has 1 good beater ring.) Or, you can send the old mixer to electronics recycling.
Best wishes.
Feb 27, 2018 | Food Mixers
Teeth on plastic gears for mixer are worn down
Even if you could obtain the parts, a 10 year old mixer is well past its prime.
Jan 17, 2018 | GE 106772 HandStand Mixer
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
Dec 03, 2010 | Cuisinart HM-70 220 Watts Hand Mixer
The mixer turns on, motor is running, but the beaters are not turning
Most likely what has happened is that the gears have stripped. The gears inside are plastic but the spindle is metal. When a dough is too heavy and gets caught up in the beaters it tends to eat them. If you take it apart, you will probably find that the gears are shot.
The fix...order new gears, tear down the mixer and replace them. These gears really should have been metal! Check the sunbeam web site for authorized repair places to get your parts.
1. Remove the ejector button...it should pop out with a flat head screw driver. There is a small phillips head screw under it. Take it out.
2. Take out the screws on the bottom. This should allow the face plate on the mixer to slide off, allowing your motor assembly to then be pulled forward.
3. Remove the mounting brackets/shock absorbers...they are rubber u shaped items that hold the motor in. Once that is done, remove the black plastic bracket on the bottom; two phillip head screws. Then unscrew the two long screws underneath. they hold on the speed control electric board as well as the top to the gear box. Pop the silver fasteners on the side of the gear box and you are in. the gears should lift out. put the new ones in and do the whole thing in reverse.
hope this helps.
Nov 29, 2010 | Sunbeam 2350 Heritage Series Mixer
I have a kitchenaid ultra power 5-spped hand mixer model khm5twh. the second beater will not stay in the socket. i'm wondering if i'm doing something wrong or if the locking mechanism has given up.
You're not doing anything wrong, the retaining gear probably has one side that is broken and it will no longer lock the beater in place. I have the same mixer and the same problem.I have searched at least 20 web sites that carry Kitchenaid repair parts and the part is no longer available. My best suggestion would be to try a local small appliance repair shop that might have the part on hand.
Feb 09, 2010 | KitchenAid KHM5DH Ultra Power® Hand...
Look under the mixing head on the bowl side. There's a square "tab" that looks like the one on the back side of the machine. Pull it towards the bowl to release the mixer head from the base.
Oct 14, 2007 | Food Mixers
Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Nov 12, 2006 | Sunbeam 2485 MixMaster Series Hand Mixer
Oster 200 Watts 2382 Hand/Stand Mixer Logo
51 people viewed this question
Top Oster Food Mixers Experts
Ross Keen
gbob59
Paul Carew
Are you an Oster Food Mixer Expert? Answer questions, earn points and help others
