Question about JVC GR-D270 Mini DV Digital Camcorder
Safe gaurd I have 2 JVC cameras stuck in safe gaurd mode. Can you help me?
    Problem Solver:
  • 5 Answers
Safe gaurd mode can mean a number of different problems, most of the time being mechanical, if you are not a tech. you will need to take it in for service.
Posted on Aug 17, 2008
SOURCE:
JVC gr dvl 500U E04...safe gaurd mode/ remove and
Poor contact of drum motor connection(flexi found at the upper part of the drum assy). Solution, disconnect this wire from the connector and cut 1mm from the end so that it will make a new contact. WIre will be shortened a little bit but it still can work this way since this flexi can not be ordered alone, it comes complete with the whole drum assy. Good Luck
Mar 14, 2010 | Video Cameras
My Jvc Compact Camcoder (GR-SXM26EA) is stuck in safe mode
thats a hardware problem .u must to open that camera and remove mechanisum u can c there is a small board behind that mechanisum .remove that board and c there is rubeer which connec to caption motor . that u put right condition than it will work
Jul 11, 2009 | JVC GR-D30U Camcorder
Trouble shooting my GR- DF550 vidio camera
mine is in safe mode 3 too and it won't go away. It's over a year old and not worth $$$ to fix. It's time to move up to a HD hard drive video. I suggest you too.
Jan 20, 2009 | JVC GR-DF550 Mini DV Digital Camcorder
JVC Camcorder Model # GR-D270U
I think youre talking about safeguard mode.
Here is the manual if you don't have one:
http://resources.jvc.com/Resources/00/00/94/LYT1354-001A.pdf
See page 51. There should be an error indication number as well.
Jun 19, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Jvc mini dv 16x optical zoom in safe gaurd mode
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
May 13, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Error message (safe mode)
HI MY MIN JVC GR D347 OPT800 RECORDER IS IN SAFE MODE AND I DISLOCATED THE BATTERY AND THE CORD AND ITS STILL IN SAFE MODE IS IT A RESET BUTTON ON IT HIDDIN
Dec 31, 2007 | JVC Video Cameras
Safe guard mode
Hi my name is Erick . Have you tried ejecting the tape??? Safe mode just means the tape is stuck or something in the mechanicism is not letting the gear works eject the tape. GOOD LUCK!!!!
Oct 23, 2007 | JVC GR-SXM470A S-VHS Analog Camcorder
E06 SAFE GAURD MODE
A jvc right? need a model but if it's what I think it's one of two things.either the belt came off the capstan motor or there are 3 connectors along the bottem edge of the main board.
Sep 09, 2007 | Video Cameras
JVC GR-D270
Try to put the camera on default settings without using battery, that is using power adapter, do this 2 to 3 times, it will solve your problem.
Jul 20, 2007 | JVC GR-D270 Mini DV Digital Camcorder
JVC GR-D270 Mini DV Digital Camcorder Logo
356 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
