Question about Kenmore Washing Machines
I have an older model kenmore front loader. The machine will not spin and will not drain unless I put the drain hose down and let it drain by gravity. Once its drained it will spin.
  • liljimmygal Aug 09, 2008
    Thanks in advance for your help!!
    Genius:
  • 1,028 Answers
Remove bottom cover and ckd pump could be bad pump motor but most likely pump is plugged and can be cleaned
Posted on Aug 09, 2008
Not spinning for washing machine
Will need a model # to answer fully. No spin could be from clogged drain hose (hose between drain and pump) faulty pressure switch, timer, or lid switch (if top loader) door switch (if front loader.) Most likely clog or door switch, but need Mod#.
Jan 06, 2013 | Washing Machines
Drum will not spin
did he run the diagnostics per the tech sheet within the machine?if it will do everything else but spin out,then the drain pump is plugged,as a plugged drain pump will shut down these front load units,you will need to remove hoses off pump and clean out pump and all hoses from tub to drain stand pipe,by running the diagnostics you can run each washer cycle and see what cycle isnt performing in a matter of 5 minutes versus 1 hour real wash time on some cycles
May 01, 2012 | Kenmore HE2 Plus Front Load Washer
Hi, My kenmore front loader washer (C44072) doesn't drain after the wash cycle. The drain pipe is straight and full of water. I have noticed this problem earlier. Before I was able to force the drain by...
check for a kink drain hose are you have lint clog up in you pump ,you have to take the lower front panel off to see the pump depend on your model.you may have the pump in back of your washer.
Apr 25, 2010 | Kenmore 43142 Front Load Washer
My kenmore front loader does not go into the spin cyclr and water is left in the drum
Most likely either the drain pump or hose is clogged or perhaps the drain pump is not working. Machine will not spin with water still in the drum.. Check all connections.
Mar 12, 2010 | Kenmore HE2 Plus Front Load Washer
Front loader
something is restricting the draining of unit either in the drain hose, but most likely in the pump remove the bottom panel and pump is in the middle and have 2 5 gal bucket handy to catch the water when you unscrew the cap to the pump ----- unless you use your wet/dry vac to empty the tub this is the best method then only a small amount of water will remain
Aug 24, 2009 | Kenmore Elite 45986 Front Load Washer
E20 error on Kenmore front loader. The water is
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 07, 2009 | Kenmore 44072 Front Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Issue with front loader going through spin cycle
you can try removing the lower acess panel(2 screws along the bottom of front) behind the panel youll see the pump assy mounted to the right, disconnect the hoses and check for debris in the hose assy. the machine will not spin if it cant get rid of water, and it cant get rid of water with a clogged hose. very commom.UNPLUG UNIT FIRST PUMP WIRES ALWAYS LIVE!!!!!!!
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Kenmore 80 series
I'm having the same exact problem, you posted this issue in Oct, have you found a fix?
Oct 18, 2006 | Kenmore 24902 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
