Question about Dell Dimension 8400 PC Desktop
Dell Dimension 8400
I just had a Dimension 8400 that crapped out on me every time I started Windows. I ran the dell diagnostics utility and it came up with a bad memory module on slot 0. Can you tell me:
1. If I have the case open and I'm looking at the motherboard, from which side does the memory increrment. From the left or right?
2. I know? I have 3GB in there but I see 4 sticks. Something isn't right.!!!
Thanks for the help.
  • 679 Answers
Look at the manual but it's more than likelly the one furthest from the edge of the board. it may tell you in one of the applications, like check you device manager or down load a free copy of Soft Sandra, from their wesite, it will give you all of the spec's for enery component in the case. It sounds like a ram mismatch taker them out and look at the individual sticksyou may have 2x1gig modules and 2x 512 gig modules, that would add up to 4 and fill all of the slots.
Posted on Dec 20, 2008
Reinstalled Windows XP on a Dell Dimension 8400 and The local area connection is not detected. Cannot seem to find drivers through Dell support
Dell Dimension 8400 PC"s use either Broadcom Extreme Ethernet controllers OR, on SOME models of the 8400 that do NOT have ON-board Ethernet connections, SMC Networks Ethernet Drivers. I've seen MANY a Dell Dimension.
Sep 11, 2013 | Dell Dimension 8400 PC Desktop
No boot device available- strike F1 to retry boot F2 for setup utility
you can try this steps to resolve your issue:
1. clean your disc drive with white cloth and alcohol
2. try to re-install the OS
3. if this won't work try to download another boot disk like EBCD
or ask a friend to create you a boot disc and try to boot your computer with it.
- This can rule out or confirm a Bad Windows OS disc, thus let's you install you Windows OS in the process.
4. try to re-install again the OS
May 21, 2010 | Dell Dimension 8400 PC Desktop
Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
I have a Dell System 8400. when booting up I get a blue screen. Stop:0x00000024 (0x0019023,0x8afac820,0xc0000102,0x00000000) restarted F2 setup then I ran full diagnostic tests. All passed. What do I need...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 02, 2010 | Dell Dimension 2400 PC Desktop
Dell 8400 runaway fan no diagnostic lights and very ocassionally it starts normally
Which fan?, the cpu fan or the cpu fan?
Most Dell pc come with a below average power supply. I recommend replacing your power supply with a better one. Do a search on Google for a good replacement power supply for you Dell 8400.
Please rate response.
Feb 17, 2009 | Dell Dimension 8400 PC Desktop
Error in system check 0f00:136c (resource cd, installation cd)
Use MS Systemrestore to restore it to an earlier time or do a complete PC backup. See Dell website below:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=5E3CADE8347C1C3CE040AE0AB5E1
Dec 19, 2008 | Dell Dimension 8400 PC Desktop
Dell Dim 8400 Issues
Hi Steve,
The problem that you are facing is most likely because of bad harddrive. As you have already replaced the RAM. To confim the same , run a diagnostics on the Hardrive. You can run the same in two ways .
Check if have the utilitu partision still left on the hardrive
1. Tap on the F12 key 5 - 6 times when you see the Dell splash screen , before windows starts to load.
2. Select Hardrive diagnostics or IDE diagnostics
If the above is no there , look for the dell Rescouce cd
1. Boot the system using the dell Resource Cd.
2. Select 32 bit diagnostics from the menu
3. Run a custom test on the hdd.
If the hardrive fails , replace the same, otherwise try swaping it connector cable with the optical cable.
Thanks
Proton
Oct 11, 2008 | Dell Dimension 8400 power supply ** FREE...
No sound from my dell 8300
  1. Make sure the speakers are plugged into the CD-ROM drive headphone jack.
  2. Reboot the system and press F12 at POST to enter the one time boot menu.
  3. If Boot to Utility Partition is an option, select it; otherwise insert the Resource CD into the CD drive and select ATAPI CD-ROM.
  4. Select Boot from CD-ROM and choose the correct options to enter the 32bit Dell Diagnostics.
  5. Run the Audio Tests within the utility.
this would let you know if the problem is with the sound card or the softare ie the drivers for the sound card
Apr 15, 2008 | Dell Dimension 8400 PC Desktop
Won't boot Dell 8400
Could be power supply, video or power switch to name a few. See this diagnostic chart.
http://www.fonerbooks.com/power.htm
Dec 29, 2007 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 PC Desktop Logo
90 people viewed this question
Alun Cox
