My computer is running very slow. So I ran test of my Maxtor 6Y160M0 hard drive using the computer's "PC-Doctor" software. The 'linear' test failed, giving me an error code the instructions said I should give to a technician. The code was 2811-201. When I reviewed the Log File from the test, I found an entry stating "Error reading block number 257199000 (of 320159385): Data error (cyclic redundancy check). What should I do?
    Sergeant:
    Champion:
  • 236 Answers
The drive is going bad
Try to format the Maxtor.
NOTE: obviously backup all important data to a removable drive or CD.
You will have to reinstall windows. so before doing this, make sure that you have the cd and Product key (usually on CD case).
Posted on Aug 09, 2008
My dell optiflex system started acting slow. OS installed is windows 7, Ram - 4GB usable - 3GB. i re-installed the OS using the re-installaation CD provided by DELL but found no improvement. i woould...
Test the computer's Hard Drive. There are a lot of reasons you might want to test your hard drive for problems. One of the major reasons to perform a test would be if your hard drive is making strange noises. This can often be a sign of a failing drive, something a test can point out.
If the problem is a software issue (virus or too much software installed on the PC) running a System Recovery should have fixed the problem. Try running a test on the computer's Hard Drive. A failing Hard Drive causes slow performance (slow boot, slow computer performance, programs takes too long to load or will not laod at all). And another indicator that the Hard Drive is failing is clicking noises. If you hear clicking noises, backup your files as soon as you can.
You can use free Hard Drive diagnostic tools what can be downloaded from the internet. One of them is Seagate Seatools.You can download it from here - click this link
SeaTools for Windows can perform several basic tests that can help determine the health of your hard drive. Your available hard drives and tests are easy to see when the program opens and can be ran with just a few clicks of the mouse.
Hope this help. Goodluck!
Apr 07, 2011 | Dell OptiPlex 780 DT/ 780 MT/ 780 SFF...
I have a Maxtor 6Y160P0. Had a fault running PC Doctor on the Hard Drive Linear Seek test; HD525-1. Clicked more info: error reading block number x of x. DataError (cyclic redundancy check). Also engine...
I wouldn't give much weight to PC doctor, or most other diagnostic software.
There are many legitimate reasons why a program may not be able read data on a HDD.
If the HDD can be formated, then all the sectors are good. Run your windows defrag, and surface test on the drive
Nov 07, 2009 | Computers & Internet
Barracuda 7200 6Y160M0 FW YAR51HW0
do a low level format with a software from hddgurudot com its free software. run it and choose this drive for low level format.it runs through windows it will make a new list of bad sectors and add it to the p list of the hard drive company settings
datarecoveryfactory
Jun 09, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
C0000218 error code.cannot boot dell 8400 to troubleshoot problem
It sounds like you've had a fatal error - you can reboot the PC back to factory setting - this is called a hard reset - but before you do that - unplug you tower and clean it out (dust & dirt) - once you're done with that - restart you computer and press &hold down the "Ctrl" and "F11" button at the same time - this will let you reset the PC to the original factory configuration.
May 03, 2009 | Dell Computers & Internet
Quantum Fireball Lct20 20 GB
Appreciate the direct "Ask Me".
A 20Gb Quantum Fireball LCT20 could be nearing its life end considering the length of time it has been in service. Perhaps what could be done is to perform a burn-in test on the 20Gb HD attaches as a Slave or Secondary on a 2nd PC or alternately, as an external mass storage device through an IDE to USB adapter. Burn-in test would be a multiple time scanning fro errors as those used by Norton Disk Doctor. Alternately, you can also Partition Magic to partition/format and eventually test the HD.
In your concern of PC slow down after 10 minutes, it is possible that:
  • the HD is slowing after some time or having difficulty searching for the called for system files;
  • heat related, either on the HD motor/bearings or even on the CPU (thermal throttling);
  • there are a number of software running in the background using the PC's memory;
  • presence of virus and/or malicious software.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 06, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
DVD-Rom drive doesn't work.
right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
May 17, 2008 | Maxtor Hard Drive
Maxtor Can't Touch
I understand the problem you are going through and it is due to the fact that win xp sp2 install an NTFS filesytem on its hard drive and this file system was designed to be secure in a way that you don't remove disk drive or add disk drives just like that.Now the best solution would be to just reinstall you xp machine with sp2 with the hard drive already in the case.In this way xp will be able to recognize it as one of its own drives and now you will have access to it.
Mar 13, 2008 | Computers & Internet
Not recognized at all
sounds like a faulty hard drive mate, if you download this software http://www.seagate.com/www/en-us/support/downloads/seatools/ and run it, it will install hard drive test software onto a floppy disk for you to test the drive from boot,
Happy new year
John
Dec 08, 2007 | Maxtor Fireball 541DX (2B020H1) 20 GB Hard...
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
