Question about Garmin 010-00358-00 GPS Receiver
Don't work with the cigarette lighter connector
Hi, I have a Garmin nuvi 660 GPS but only take charge with the A/C charger, what can i do?
  • 928 Answers
Check if you are able to charge other devices via the cigarette lighter such as a cellphone or try to use the lighter if the light does not get as hot as normal then that means that there is not enough power. If that looks ok then try another cable charger for your Nuvi
Posted on Aug 20, 2008
I've borrowed a friend's Garmin for a trip and when I use the car charger, it doesn't display anything. Once I disconnect, it becomes visible again. I'm going on a long trip and worry. ...
Assuming there is power at the cigarette lighter jack - turn the Nuvi off - then connect the charger. It should display charging battery or charging complete.
If nothing - does it charge with the wall charger? If so check the fuse in the car charger - it's usually in the tip of the charger which can be turned to get the fuse out.
Jul 05, 2011 | Garmin Nuvi 660 GPS Receiver
MY GARMIN NUVI 650 NA SUDDENLY STOPPED WORKING. WHEN I TOUCH THE SCREEN NOTHING HAPPENS... (THIS MACHINE HAD BEEN WORKING SINCE 2007). PLEASE HELP
Is it charged? If you are using the cigarette lighter adapter plug, there is a fuse in the silver tip of plug...... unscrew it carefully..its spring loaded... check fuse
Oct 27, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 ~5yrs old. With auto charger connected the unit powers off quickly with low battery indication. However if charged overnight on a USB cable the unit operates fine and indicates the battery is...
You probable have a blown fuse in the cigarette lighter adapter.... Unscrew the silver tip of plug and check fuse..... be careful its spring loaded..
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
Car power unit charge not working
if the light is on the bit that goes in cigar lighter in car then fault in unit or wrong charger being used, i f no light on charger the replace/check fuse in charger ( unscrew tip ) and or check cigar lighter working in car
Dec 26, 2009 | Garmin Nuvi 660 GPS Receiver
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
How can I recharge the battery on my Garmin Nuvi?
Just use your USB cable that came with it to connect it to your computer. It will charge just fine. You can also use a cell phone charger that has a USB connector. A lot of cell phones use this type of charger now and the charge will work fine with the GPS>
Apr 01, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi does turn on when connected to power in car
Hi
I had the same problem. My Nuvi 350 did not power up for a couple of days. I suspected moisture to be the culprit. So I took my wife's hair dryer and blew hot air(in the intermediate setting) into the SD card slot in the GPS for a couple of minutes. Take care not to overheat the GPS or Screen.
Pronto my GPS powered up without any issues.
Hope this helps
Oct 24, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi-660--garmin
Yes be sure your battery is full charge, go on the GARMIN web site and do an update.
Install the web updater from GARMIN.
If you have a battery low its normal. You did not mentionned into your comments that you had try a charge. I can not assume but i hope you did.
No problem with the battery was reported from GARMIN at this time. Everything is reporting fine by many others users.
Jan 03, 2008 | Garmin Nuvi 660 GPS Receiver
FM Traffic Cable for Nuvi 660
I just replaced the fuse and it works fine, thus saving a couple of
C-notes. Who's the idiot?
Nov 23, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin 010-00358-00 GPS Receiver Logo
93 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
