Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG front loader
The machine I bought today knocks really bad on spin cycle? They told me under neath the machine you had to do something to it to fit it? Do you know what it is?
    New Friend:
  • 60 Answers
There may be a block of styrofoam still under the unit from the packing material or the 4 shipping bolts might still be in the back.
Posted on Aug 15, 2008
SOURCE:
Whirlpool SM8281115
You probably have the end of the outlet hose too low to the ground it should be about half way up the back of the machine or fitted into a stand pipe.
http://selfix-uk.co.uk/under%20sink%20plumbing.html
or the water entering the machine will just siphon out
Mar 28, 2017 | Whirlpool Washing Machines
Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Aug 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
The Washer did not spin
MOR PROBELY THE CUPLER WENT OUT IS A 3 PEASE 2 WHITE AND 1 BLACK PART IN BUTTEM OF WASHR BETTEN THE MOTOR AND TRANMISION OR CK LID SWITCH. GOOD LUCK
Jul 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud knocking sound
You have a bad drive block. This block is located under the inner tub. A special spanner wrench is required to remove the tub. You really need to call a service tech for this repair.
Apr 15, 2009 | Whirlpool LSB6200KQ Top Load Washer
Atlantis washer
Dear Spencer,
OH the trouble I have seen with my washer. Its only 8 years old and I had the same problem with mine it would fill up the rinse cycle and then just sit there with the water in it. I had a tech come out and he told me I wasn't distributing the clothes correctly, mind you I'm 54 and I think I know how to do laundry!
However I had just 1 month ago replaced the water pump because my son decided he wanted to do a weeks wash in one load. So what I think happened is that somehow the machine was knocked out of being level. The guy said he lubricated the motor cradle and leveled the machine, knock on wood just for today the cycle is running all the way through. Hope this helps
utah55
Jun 24, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
151 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
