Question about Whirlpool WED5100SQ Front-Load Electric Dryer
Dryer problem We have had this Whirlpool dryer for only 5 months. The past few days, the main circuit breaker in our house kicks off every time we turn the dryer on. Tonight, my husband pulled the dryer out to check the cord and we found that the exterior of the dryer was extremely hot but the clothes weren't dry even though they'd been in the dryer through 2 full cycles. Any ideas on what could be causing this?
    Genius:
  • 1,028 Answers
Ck vent system to outside also ck the vent hose behind dryer to be sure it is not being mashed flat when pushed back..while you have it out ck to see if cord connection screws are tight loose screws can cause cord to overheat and melt insulation causing short..if breaker trips immediately suspect dryer if runs for a time before kicking suspect weak breaker
Posted on Aug 09, 2008
Main breaker keeps kicking, yesterday it effected the dryer, washer and lighting! Turn dryer on and lights worked, turn it off and lights would go out! Washer wouldn't run at all. Thought the house was...
I would be inclined to think the main breaker is almost worn out and needs replaced very soon.If it's taking out the main instead of individual breakers I would get a good electrician on it right quick. Good luck and thank you.
Feb 21, 2011 | Electrical Supplies
My Maytag Bravo Steam Dryer runs for about 5 minutes and gets hot and then kicks the breaker in the breaker box. HELP!!
Hello there:
It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:It could be also wired backwardes so make sure to have this checked'
If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician. If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box.
May 21, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My whirlpool dryer kicks my breaker after running for about 40 minutes, the clothes are not dry yet when it kicks the breaker. It does this on the high and medium settings both. My husband replaced the...
Check your circuit breakers.Most of the time when breakers get older they can't hold the current load. Also make sure the wires that connect to the breakers in the main panel are tight in that circuit..Be careful I had a dryer that did the same thing. Check to make sure the lint is cleaned out so there is no obstructions that's creating a air flow problem. The dryer gets to hot and shuts down.Well that was my problem.Just an idea.
Feb 06, 2010 | Dryers
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
Dryer keeps tripping circuit breaker. neither new.
This is common, I see it about 4 or 5 times a week. Your heating element is broken. The broken end of the element is touching the element housing. This is easy to replace after you remove the back of the dryer.
Please rate this solution
Sep 01, 2009 | Whirlpool Dryers
Clothes Dryer tripping house circuit breaker
If it is breaking the main circuit of the house there is something wrong. It should throw the breaker to the dryer only. It sounds like you are having a problem with a short between the main breaker and sub panel in the house. Is there any way you can move the breaker in the panel to a different place on the same panel to see if it is that circuit only. If not check the outlet and the plug on the dryer and make sure the wiring is connected correctly.
Aug 03, 2009 | Dryers
Dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Apr 21, 2009 | Dryers
Whirlpool dryer will not heat properly
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool WED5100SQ Front-Load Electric Dryer Logo
105 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
