Question about Microsoft Xbox 360 Console
Broke i came home and when i plugged it in i bout a cooler and and remote the 360 broke i turned it on and on the screen the audio works but the screen have white dots on it moving.
    Sergeant:
    Champion:
  • 236 Answers
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
1.Remove any discs from the disc tray.
2.Turn the console off.
3.Turn the console on.
Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
Note Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console.
Posted on Aug 09, 2008
Replacement remote for Jamo 360 soundbar
Amazon.com: Replacement Remote Control for JAMO TORSTEN 360 ...
https://www.amazon.com/Replacement-Remote-Control-JAMO.../dp/B01E67NI6U
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. *This is NOT an original JAMO remote ...
Replacement Remote Control for JAMO TORSTEN 360 ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls US$38.81 - ‎In stock
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. This is NOT an original JAMO remote ...
jamo replacement remote ' AVForums
https://www.avforums.com > ... > Home Cinema Speakers Oct 5, 2014 - Hello, I have jamo p102 speakers. Unfortunately the remote is broken which means I can't control the speakers at all now. It can't be fixed. Is it... Replacement remote for Jamo 360 soundbar Google Search
Feb 01, 2017 | Jamo Audio Players & Recorders
Remote 4 paramax p-510
I have found that when a remote takes a hit ...the led which is normally standing out on two very thin wires bends downward, if you can pop off the cover you might find this is the problem.....
Apr 29, 2014 | Audio Players & Recorders
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
I have a nyko cooler and i think taht it doesnt work well because when i turn on the 360 it says e68, but when i take out the cooler and i turn it on, it works well
The power supply (aka the power brick) gives out a specific amount of power for your 360. It may not have enough power for the extra cooler too depending on your setup.
Jun 12, 2009 | Microsoft Xbox 360 Console
No picture on xbox 360
did u make sure the audio cords r plugged in tight? or they could be in a hd slot when there not hd or the other way around and look at one of the cables in the back and make sure its on the right one/ hd or tv
Mar 15, 2009 | Microsoft Xbox 360 Console
Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
Jan 03, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Xbox 360 Not Reading Disks
idk bout the blue screen. but my console would say the same thing bout put in 360 to play and it wuz cuz the disk was dug in a lil bit so it wouldnt read.
Dec 31, 2008 | Microsoft Xbox 360 Console
My 360 is it broke?
just check the av cable you are connecting the console with the tv and check tv settings for the same. i dont think you need to hold any buttons its just a cable problem what is sounds to me.. change the cable if tv is working fine or just check the connections at your friends place and make a note of that and to the same thing at your place with the same connections..
tell me if this works !!
Have a nuce day !!
Apr 18, 2008 | Microsoft Xbox 360 Console
Xbox 360 no video but have audio after playing madden
Something to try is just leave the xbox on for an hour, turn off let cool for 5 min. If that doesn't work, it's a difficult solution to recommend but the towel trick' does work, let it over heat the 360 for about 20 min, then let it cool for 20 more min, and it now works fine, I have a inner cooler now to keep from overheating again.
Jan 03, 2008 | Microsoft Xbox 360 Console
No Image
Make sure you are on the correct TV Setting. Most TVs have different video settings such as TV, Video 1, Video 2, Component, and many others depending on what type of tv you have. You can find the button on the TV remote. It will probably say something like "TV/Video" on the remote. Hope this helps.
Aug 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
