Question about Dell Dimension 2400 PC Desktop
User32.dll error message
When trying to reboot I am getting a blue screen with the message: stop: {c0000135 unable to locate component} this application has failed to start because user32.dll was not found. reinstalling the application may fix this problem.
what application? can I do it without losing everything? how? HELP!!!!!
  • fschuurmans Nov 15, 2008
    after update avg impossible to startup, safe mode accessable however will not start up and returns with same error message as in normal mode start up. Any one a suggestion how to overcome this issue since all avg error solving methods failed since i can not start up in whatever mode
    New Friend:
  • 43 Answers
User32.dll is an important file which should normally be on your computer. You should never remove this software because it is essential. To Resolve User32.dll Errors just follow this link.
Posted on Sep 02, 2011
  • 16 Answers
I suggest you go do a google search and look for spybot, it has a registry FIX and scanner built in that will successfully immunize your system from hijacking website cookies and trojans, and bring your system to as close as functional as possible, then go to download.com and grab AVG anti-virus, do a complete scan, delete everything that shows, or quarantine after a successfull complete system scan. Be sure to reboot after EACH successfull AVG scan, as the program cannot delete high memory cookies or hijackers, and can only do at a system start up, before these programs go into high memory(RAM bits and bytes that users cant touch when a system is operational and fully booted up).
I hope this helps you a bunch, I have had the same DLL problems with my father's PC being hijacked from REGISTRY EDITOR cookies and trojans, mostly harmless key coder programs to watch your surfing.
If this does not help, then you are past repair on my levels and require a reinstall of the operation system and clean format of your drive. Attempt to backup all your important files to a DVD or TWO so that you can recover.
LAST RESORT is to partition the drive that you are using, and set up a system restore for your windows on this partition, if you EVER get this type of error again, if its not a corrupted video card or system driver, you can restore your PC on a clean backed up system, and retain all of your files and documents.
Just a suggestion, most will find this usefull..
ManOWar
Posted on Aug 09, 2008
6ya staff
SOURCE:
Missing user32.dll
User32.dll errors come from issues inside Windows that involve the User32.dll file. This file contains important information regarding graphics details for objects such as dialog boxes. When there is an issue with the file, there will be problems when using other programs that use dialog boxes and other pop-up windows. Normally, a quick Windows update will solve all errors and problems.
Click the "Start" button and then "Run." This will open the "Run" window. Type in "wupdmgr". This will open Windows Update. It will now scan the computer to detect any necessary updates that are available from Microsoft. Turn on automatic updates by clicking "Start" again, followed by "All Programs," then "Windows Update." Select "Change Settings"; then select "Include recommended updates when downloading, installing, or notifying me about updates." Click "OK" and everything will be set. Windows will download the necessary update and install it to correct the User32.dll errors Hope this helps.
Jan 21, 2013 | Acer Aspire One Netbook
Emachines T4010 won't start up, says image checksum, and that an image is corrupted
Receiving a bad image checksum error message when upgrading a computer to Windows XP means that a Windows system file such as user32.dll is damaged. This error occurs when any damaged system file is encountered that isn't overwritten during Setup. The repair process for this error involves voiding the damaged dynamic link library file from the DOS command line prompt and replacing it with a new copy from the Windows XP disk.
Insert a clean Microsoft Windows Millennium Edition (ME) or Microsoft Windows 98 Edition startup disk into the computer, and hold the reset button on the front of the computer until the system commences rebooting. Navigate the Windows startup menu with the keyboard's directional keys and select 'Start Computer with CD-ROM Support'. Hit "Enter" to continue. Write down your CD-ROM's drive letter on a piece of paper. At the command prompt, type "Drive:" without quotes (Drive should be replaced with the drive letter on which Windows is installed), and press "Enter." Type "cd windows\system32" without quotes, and press "Enter." Type "ren user32.dll user32.old" without quotes and again press "Enter." This renames your damaged user32.dll file so it is not recognized by the system, but still physically exists as a backup if needed in the future. Eject the Windows ME or 98 disk, and insert the Windows XP disk. At the command prompt, type "extract CDROMDrive:\i386\user32.dl_ Drive:\windows\system32\user32.dll" without quotes, replacing CDROMDrive with the CD-ROM's drive letter that you made a note of earlier, and replacing Drive with the system's drive letter on which Windows is installed. Hit "Enter" to execute the command. This process extracts a new copy of the user32.dll file to your hard disk, from the Windows XP CD. The new file will be found in the Windows/System32 directory. Restart the system by holding the reset button on the front of the tower until reboot commences.
Jan 03, 2013 | Computers & Internet
I am getting stop: c0000135 unable to locate component, this application has failed to start because MSVCR80.dll was not found.. how do I fix when i cant get past the blue screen?
Not sure what os you're running, and assuming it's xp, but see helpful links below.
To get past the blue screen, you need to press f8 during boot up, try using last known good configuration to start windows. Otherwise, try booting into safe mode. See the Reboot instead of shutdown section in this article. to disable the restart on system failure. Also helpful may be this link or this link or this link. Here's one more I saved. Unfortunately, many of the MS links are no longer valid, now that support for xp is dropped.
If you can run chkdsk on the system, you might be able to recover corrupted or bad sectors that caused the dll to be lost. For a list of device error codes, see here.
Also consider the possibility that malware is responsible. In that case, use MBAM to scan the system.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 21, 2010 | Computers & Internet
When starting the computer, after the Windows XP logo screen, I get a black screen that reads "Analog input cannot display this video mode." When I clear that screen, I get a blue screen with the following...
Boot your computer2_bing.gif to safe mode and change the display settings to either 800x600 then save and reboot2_bing.gif once it comes back up you can change the display setting to what you prefer.
To get into safe mode press F8 on you keyboard2_bing.gif every second while it is first booting up.
Mar 09, 2010 | Microsoft Windows XP Home Edition
Stop: C0000135 {unable to locate component}
ok if is win xp just run the xp cd and choose repair that should solve it
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_08785c7d726a554e
Aug 31, 2009 | Dell Dimension 2400 PC Desktop
Dell Vostro will not boot up
During startup, just before the Windows splash screen appears, you should be able to hit the F8 key for a list of startup options. It looks from your post as if you know how to do this.
One of those choices should be to disable automatic restart on system failure. (or words very similar to that.) Use this choice to get into safe mode if you can, or into regualar windows.
Once there, go to the system restore feature and restore to a date when everything worked.
This error message is a message pointing to a piece of software (as opposed to hardware, as so many of these messages are).
The next best fix is to reinstall the OS from the ground up. this may be a major hassle, depending on the data you have on that hard drive.
Good luck
tony
May 18, 2009 | Dell Vostro 1700 Notebook
Blue screen c0000135 user32.dll not found
Did you install something or Edit something prior to this happening? How old is the laptop, if it is more than 3 years old then replace the hard drive.
Feb 01, 2009 | Computers & Internet
When starting up Windows XP - the process stops and I get the message C0000135 application failed because user32.dll wasnot found. I have tried to start in safe mode but the same problem re-appears. ie:...
I've just seen this on another users pc, here is how i solved it:
Start from your xp disk (recovery disk that you got with your machine or retail copy of xp), when prompted go into recovery mode (press r at the menu)
when in the recovery mode go to c:\windows\$NtServicePackUninstall$ and type
copy user32.dll c:\windows\system32\
then type 'exit' without quotes to reboot
your system will now boot up fine
(note there may be a copy of the user32.dll file in c:\windows\system32\dllcache\ as well)
Dec 10, 2008 | Computers & Internet
Laptop worked fine the other night went to shut it down and it then said that an update was needed before it turned off so it done that and then turned itself off.went to turn it back on the next morning...
boot up computer and as screen starts up keep tapping F8 to go into safe mode and then go to system restore and restore to a date before the update and it should work for you ..... it may have not been a real update or it just didnt load right / larryyb
Nov 28, 2008 | Acer Computers & Internet
RTHDCPL.EXE err
Error Message after Installing Security Updates 925902 and 928843 This afternoon (April 3rd, 2007) my Automatic Updates alerted me about a couple updates I needed to install, so I did. Upon rebooting the computer though I was confronted with the following error message
"RTHDCPL.EXE - Illegal System DLL Relocation"
"The system DLL user32.dll was relocated in memory. The Application will not run properly. The relocation occurred because the DLL C:\WINDOWS\SYSTEM32\HHCTRL.OCX occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL."
Cause of Error Message
Turns out this error occurs when the Realtek HD Audio Control Panel by Realtek Semiconductor Corporation is installed. This is my built-in sound card on my computer.
The HHCTRL.OCX file that is included in the Security update 928843 and the User32.dll files that is included in Security Update 925902 have conflicting base addresses. When Windows loaded the HHCTRL.OCX file before it loads the User32.DLL file, the problem occurs.
The error occurs when the following third party programs or applications are installed on a computer with Windows XP Service Pack 2 installed.
ElsterFormular 2006/2007
TUGZip
CD-Tag
Microsoft now has released a patch to correct the problems, you can go to the following link to download and install the patch for the patch :-)
http://support.microsoft.com/kb/935448
Oct 18, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
649 people viewed this question
Ekse
Clive
Clive
Alun Cox
