Question about Lexmark JetPrinter X1185 All-In-One InkJet
Need help color cartridge won't print
  • 659 Answers
Did you remove the sticker and transparent tape from the print
cartridge?
Is the color cartridge secure in the left carrier?
have you recently changed carts?
Posted on Aug 12, 2008
  • 7 Answers
SOURCE: color printing
GO TO MAINTANANCE SECTION IN THE MENU TRY TO TAKE SELF TEST PRINT.
IF IT COMES THEN GO TO NEXT STEP AND TRY TO CHECK THE INK LEVEL OF THE CATRIDGES IF THE INK LEVEL IS LOW DO REPLACE WITH THE GENUINE CATRIDGE ITSELF.
Posted on Mar 01, 2008
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
  • 240 Answers
SOURCE: hp 5510 io keeps stating to check color cartridge/3 lights blinki
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Posted on May 12, 2009
Salim Baig
  • 283 Answers
SOURCE: My Epson printer R32o won't
Hi
Have you checked the settings if they are set to Grayscale only or use black cartridge only. Options in printer settings? try to restore all to default settings and this will solve your problem.
Take care
Posted on Jul 16, 2011
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: i've installed color cartridge but it
    Try to re-insert the color cartridge into the printer and make sure it is properly seated in the cartridge carrier.
    If that doesn't help, try to clean the print nozzles. Please follow the steps below:
    1. Press Copy. 2. Press Options until Maintenance appears on the display. 3. Press the right arrow until Clean Cartridges appears on the display. 4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles. 5. Print your document again to verify that your print quality has improved.
    Posted on Oct 24, 2011
    Dell printer won't print
    It may have a date code ill not allow you to print without updating/replacing the cartridge. I got rid of hy HP for the same reason.
    Jun 03, 2017 | Dell AllinOne Multifunctional (v515w)...
    Color won't print - Deskjet F4210
    you are having a defective printer head so just got it replace or get another printer
    Feb 04, 2013 | HP Deskjet F4210 All-In-One InkJet Printer
    Won't print in color
    How long have you had color ink cartridge in the printer for? Have you triple checked you have set the settings to print color? If it still persist then the possibilities are your ink color cartridge is out of ink? have you made sure it's installed properly?
    If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
    Dec 14, 2012 | Canon Pixma MP480 All-In-One InkJet...
    My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
    You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
    Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
    Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
    I've installed color cartridge but it won't print in color
    Oct 22, 2011 | Lexmark X6170 All-In-One InkJet Printer
    HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
    None of the cartridges can be empty if you want to print.
    Even if you only want to print black, just black you need to
    replace the other three cartridges.
    Yes color laser printing is expensive.
    Jul 14, 2011 | HP Color LaserJet 2600n Printer
    Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
    Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
    You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
    Jun 30, 2011 | Computers & Internet
    New tri-color cartridge has a problem. I can't see what.
    I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
    Tri-color.
    And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
    Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
    Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
    hi..
    Apr 01, 2009 | HP Officejet 5510xi Printer
    Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
    Lexmark JetPrinter X1185 All-In-One InkJet Logo
    44 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
