Question about RCA F32649 32" TV
Perfect sound, no picture - RCA F32649
TV is a RCA F32649, date of manufacture is September 2001. About three months ago, the picture on the coax input started exhibiting some flakiness - sperfect picture, then snowy, then no picture, then perfect again. After two weeks of that I reconnected everything to run through the rear audio/video inputs and things were perfect. This morning when the TV was turned on, the sound was still crystal clear, but there was no picture. In an effort to further diagnose (and avoid buying a new TV) I recabled everything this evening to use the front A/V inputs to no effect. Again - perfect sound, no picture either from satellite receiver or DVD player. Any guidance that can be provided would be greatly appreciated. Hoping that this TV can be repaired at a reasonable cost, and with a reasonable expectation of a decent lifespan following the repair.
    Champion:
  • 252 Answers
If you know how to solder ,re solder your tv, but before doing that replace or used other RCA cord
Posted on Oct 31, 2008
What year was the RCA TV Model F19426 manufactured?
Since the manual has a copyright date of 2001, I would guess that the RCA F19426 was manufactured in 2001 or 2002. ManualsLib has the manual for this TV: https://www.manualslib.com/products/Rca-F19426-328410.html . The last page, https://www.manualslib.com/manual/138735/Rca-F19426.html?page=64#manual , has the copyright date.
I hope this helps.
Dec 22, 2016 | RCA Televison & Video
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Aug 24, 2009 | RCA F27442 27" TV
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Oct 24, 2007 | LG LRSC26980 25.2 cu.ft. TV Refrigerator...
No Picture on TV
? What is the model # off the back ?
Does the video work on the RF coax cable input?
For instance,as a test,can you hook-up from VCR coax RF out
to TV coax in,put the TV on Chan. 3,play a tape and get audio and video?
Are you matching colors when trying the A/V inputs?Yellow,red,
and white out of DVD to yellow,red and white in on back of TV?
Then select video input on tv===dial "00" or use input button on
original RCA remote. Are you using original RCA remote that
came w/TV ? Do you have the owner/operator manual for the TV?
   Sorry to ask so many  ?????   Let me know how it goes!!  T.
Oct 17, 2007 | Televison & Video
RCA 25GT511 - fuzzy picture slight static sound; wiggle coax rear mount temp resolve
There might be a bad (loose) connection in the RF isolator or the tuner (both are silver boxes. Try to unplug the coax and bend the RCA tabs in so that the connection gets firmly made when reconnected. This may help. If it does not The connector may have to be replaced.
Aug 08, 2007 | RCA 32V550T 32" TV
RCA F32649
Sounds like you have a shorted horizontal out put transistor and bad flyback transformer. This is a common problem in the newer RCA's. I've had serveral of them do this. The noise that you hear is the power supply telling you that it's overloaded. Stargazer
Feb 17, 2007 | RCA F32649 32" TV
No sound
have you check with other input like a vcr?...good luck
Aug 10, 2006 | RCA F32649 32" TV
RCA F32649 sound but no picture
This usually a problem on/near the horizontal section of the TV board caused by solder that losses its contact thats why you need to bump it sometimes for the picture to come out. To remedy this just try to resolder any parts that you suspect seems to loose especially in the part where the components tends to get hot when operating, this usually are the horizontal section or the power supply section which is very common.
Apr 10, 2006 | RCA F32649 32" TV
RCA F32649 32" TV
I had the same problem with a nearmodel. It was the high voltage splitter. It cost me $380.00 canadian
Nov 15, 2005 | RCA F32649 32" TV
RCA F32649 32" TV Logo
166 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
