Question about Kenwood KW85 Air Conditioner
Kw85 blows cold for 10 min. than kicks to fan. Doesnt seem to be filling any water
    New Friend:
It's caused on that unit by the thermostat on the compressor getting too hot
To test take the back exhaust right off and run it for 20 minutes if it works now then get a 5 inch diameter hose and a bigger exhaust outlet. I had a 4 inch hose to a smal outlet and it was causing it to overheat
Posted on Jul 26, 2015
  • 236 Answers
Your base pan may be full of water, check at the bottom of the unit for some drain plug. Drain out the water and start the unit.
Posted on Aug 14, 2008
I have a 05 scion tc that the ac compressor will blow ice cold and after a few mins the compressor will kick off. If u turn the ac off for a few mins and turn it back on it will blow cold for a few mins...
may be a few things try checking the a/c lines when it does the shut off thing are they freezing up? may need a dryer. is the fan coming on at the radiator when the a/c comes on? it needs this to keep the head pressure down. does it drip water when the a/c is on under the car? may another sign its freezing up.
May 04, 2012 | 1953 AC 2 Litre
Maytag refrigerator mtb1954eewoo does not seem to be as cold as it should be air doesnt seem to blow
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 26, 2011 | Maytag Refrigerators
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
Case 580 m ac will come on blow cold then the light comes on and it stops blowing cold you can turn ac off for bout 1 min and turn it on it blow cold and kick off light on manual say light eather high...
take a garden hose or somthing with high water pressure and spray out all of radiators in the front of machine. This will clean out all the dust build up between all the rads and will cause your fan to cool the ac fluid as well as the others
Aug 05, 2010 | Ertl 580 Super M Series II Tractor
My air conditioner is not producing any water
It will take a full season of runnig to produce a cup of water. Most moiisture evaporates and is exhausted out the hose.
May 31, 2010 | Kenwood KW85 Air Conditioner
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
9200 weather maker does not seem to blow heat, it will trip limit switch at fire box, smeels like unburned gas when running, what might be the cure.
i turn my heater on, then it shuts off 3-4 min later, approx. 10-12 min l8r it turns back on... the fan doesnt run enough to cool, or heat my home... im cold and kinda upset about the whole situation... anyone got a clue?
Apr 30, 2008 | Carrier Heating & Cooling
Fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
May 28, 2007 | Sunpentown WA-1210E Air Conditioner
Kenwood KW85 Air Conditioner Logo
188 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
