Question about Samsung RS2630SH Side by Side Refrigerator
Divider red hot
I opened up the back of the fridge and the tank was REALLY, REALLY hot. Nothing blocking the fan from moving. I vacuumed the entire back area and left unplugged for several minutes. Fan spun as soon as I plugged in.
Will this fix it? Why did the tank get so hot?
Thanks.
Amy & Eric
  • 725 Answers
"Nothing blocking the fan from moving" was it spinning?
Is it cooling in the freezer?
the compressors do get hot ..but if they are not cooling the relay could get stuck on the start windings .. you will need to replace it..
Posted on Sep 01, 2008
Bosch double door fridge divider hot, is this normal?
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink.
May 09, 2012 | Bosch Refrigerators
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
Roper center divider hot
Either a bad condensor fan motor ( fan which cools the compressor ) OR dirty coils . Remove the kickplate and vacuum .
Aug 02, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
The divider strip between the freezer and the fridge is super hot. Both sides are still working fine, but it hasn't been this way until the last few days.
When the face of that divider gets really hot, it's because the condenser coils are unable to shed heat properly. Check to see if the condenser fan is running - it's the one that blows air across the coils under the fridge. If no air is moving, then you need to replace it. If the fan is working, then check for any obstructions and use a vacuum cleaner to clean the coils. Make sure there's enough space behind the unit for air to flow.
Jul 22, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Cooling Fan is not working automatically
thass as good idea, but instead justreplacethe existing fan ( which is your problem)the fan is no good, so rewiring will not help any. replace the part!
Mar 18, 2009 | Whirlpool ED5VHGXM Side by Side...
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Center Column is getting Hot
The light for the filter is not a problem. The thing to check is that the fan in the back is running. It should run any time the compressor is running to cool the compressor. If it is, then you need to pull the front grille or toe kick off and look under the fridge. Is there a lot of dust and dirt blocking the airflow? If so, vacuum it out. If not, pull the fridge out and check behind it. Is there a grate clogged up with dust? The reason the divider gets hot is because there is a freon line running through that part of the fridge to keep moisture from forming around the door seals. If the fridge is not cooling properly (dead fan motor or dirt blocked airflow) then the freon in this line gets very hot and all the pressures in the system rise, eventually leading to the fridge not cooling. Good Luck !
Oct 07, 2006 | Frigidaire FRS23H5AS Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
91 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
