Question about JVC GRDX77 MiniDV Camcorder
EO3 message on JVC GR-D72U
I have been getting the E03 message and I do not know how to fix it. I have tried eject-reinsert, power off-power on, and battery removed-battery returned. What else should I be doing?
  • 6,487 Answers
Try this press the record button and hold, then press the manual focus button and release both.
Hope that helps.........
Posted on Aug 09, 2008
    Scholar:
  • 191 Answers
Please try a hard reset first as you need to take the battery out and leave the camera without the battery for two hours and then check the status
SOURCE:
I have a GR-AX820 VHS. I'm getting error message EO3 and the tape keeps breaking. What do I need to do?
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!)
Jul 09, 2008 | JVC Televison & Video
E03 eject and reinsert tape
Because of the black rubber part you have that problem so now you need to find one and insert on the bottom part of you tape deck for your camera to work.
Feb 11, 2014 | JVC GR-D73E Mini DV Digital Camcorder
Have a JVC GR-D72U video camera. A E03 indicator keeps coming on and it goes into safe mode. What can be done? How can it be fixed?
This problem mostly happen due to defective cassette, by ejecting it, it will solve your problem. If your tape stuck-up inside, apply power, open cassette door, keep it open (around 5 sec) until it opens. and try with another cassette. It must work if not, expert are needed in this case. Good Luck
Aug 30, 2010 | Video Cameras
EO3 is comming up
Many possible causes, mostly coming from the tape. I hope tape is still can be ejected, try to change with a new one. If still persist, something wrong inside could be a belt or the capstan gear broken. If you know how to open your next problem is the spare parts. Good Luck!
Jun 10, 2010 | JVC GR-D90U Camcorder
Error code E03,camcorder shuts down,won't eject tape.How do I fix it.
E03 means the motor drive has failed.The damage is permanent. The camcorder GR-AX5 is too old to repair.Recycle it and buy a new one.
Nov 10, 2009 | JVC GR-AX230 Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Dec 04, 2007 | JVC GR-DVL20EG Mini DV Digital Camcorder
Video Cameras Logo
557 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
