Question about Casio Parts Cash Register PC Desktop
Royal Cash Register
Ink over the printed and unprinted register tape....if I only advance the tape I get black marks to the right of where the numbers are. If I ring sales the print out is hard to see as there is what appears to be smudged strips of ink over the printed number. It is a new ink roller....It started with the old one, after replacing the ink roller it only got darker....still can't read the numbers..tried to mop up the well that has the ink pad in and the numbers that I could get to used alcohol on q-tip. still smugged
Royal 435 dx electric Cash Register
  • 737 Answers
Hi. There are several reasons for this.
The most common one is not replacing the ink roller on time. If the old roller had felt falling off of it, then it will block up the drum.
The second is re-inking the roller. If you do this, you end up with a sticky mess and a lot of smudging.
Other than that, pieces of paper stuck in the paper path are common.
You should inspect the drum again. This is the little group of rubber numbers that spin around and hit the paper while printing. You will usually find sticky muck on the numbers, and you may have to clean them several times. You need to turn the drum as you clean it. Try to use the gears at the side if they are visible. A dry Q-tip is best, as alcohol may damage the thin rubber. Try cleaning the drum again, and look for any improvement. If itgets better on some numbers, then you are probably on the right track. Also, if you could send me a picture of the bad print, that may help also.
Good luck.
Mark
Posted on Aug 09, 2008
Royal 500dx cash register is printing all the characters to far left of receipt, overlapping so they are unreadable. Does not do it all the time.
I think the rack on your printer is worn out, Get a tech to replace it for your or better still replace the whole printer.
Feb 13, 2015 | Royal Cash Register 500dx
Howto change register tape
Manuals (cost)
They also do casio, TEC,Casio,Sam4s,Epson,Sharp,CAS,NCI,ApexInk,ApexCovers,ApexRolls,Metrologic,Datacap
Systems,Sanyo,Royal Sovereign,Restaurant Edge,Detecto,Uniwell,Datasym,Harbortouch and Telequip.
Cash Register Store Buy Quality Cash Registers Online at Low Prices...
Manuals download
(not free)
ADS Anker,Aster,Casio,Metrologic,Olivetti,Olympia instruction manual,Omron cash register,Royal,Samsung,Sam4s cash
register,Sharp,Tec cash register,Vectron,Walther,Wincor Nixdorf,Machine setups
Not Epson, Apex,Datacap Systems Sam4,CAS,Uniwell,Sanyo,Royal Sovereign,Restaurant Edge,Detecto,Uniwell,Datasym,Harbortouch
and Telequip.
Manuals Downloads
Manuals free view
ABC Office,AMD,AVE,Casio,Delta,Ele,Epson,Goodson Imports,HP (Hewlett-
Packard),Lexmark,Mars,Olivetti,Olympia,Olympia/Luggage,America,Pelco,Philips,POSIFLEX Business Machines,Radio Shack,Royal
Consumer Information, Products,Sam4s,Samsung,Sanyo,Sharp,Sony,Toshiba,Unitech, and Weider
Free Cash Register User Manuals ManualsOnline com
May 26, 2014 | Royal Cash Register 500dx
How to change register tape
The Royal family of cash registers run in the last two letter designation. So, you can find the same essential answer to your question within the User Manuals for the Royal 110DX, 135DX or 435DX available at Royal's website at:
Drivers Manuals
I hope this helps!
500dx won't print total price with tax on register tape
GO to printing options and select choose 1 where it asks to print or not the tax incl
Jan 22, 2014 | Royal Cash Register 500dx
How do i install ink cartridge in royal alpha 1000ml
There is NO ink in your cash register.
Your cash register has a thermal printer that prints receipts for the
customer or a journal tape. Use 2¼ inch (57.5 mm) wide standard thermal register paper. Do not use bond paper because the register does not use a ribbon or ink for printing.
See installing paper roll on page 13 of the manual
Royal 1000ML Instruction Manual
Nov 24, 2013 | Royal Office Equipment & Supplies
Installing ink cartrage in a royal 435dx cash register
1. Open the printer compartment by lifting the black, plastic printer cover.
2. The ink roll is found in the front of the printer compartment, just behind the print
head, and is mounted in a plastic cartridge.
To remove, grasp the small clip on the left of the ink roll (where the words "PULL UP" may
be printed on the ink roll cartridge) and pull up.
The ink roll will easily pull up and away from the print head.
3. To replace a new ink roll, insert the ink roll according to markings "L" (Left) and "R"
(Right) by pressing downward to lock it into position, then close the printer cover. No tools
are necessary.
For best performance, store unopened ink roll package in a cool, dry place until installed.
NOTE: Replace with ROYAL Ink Roll, Part #013109.
Nov 16, 2010 | Office Equipment & Supplies
Royal 482cx cash register constantly running the reciept motor.
Tom, we have the same problem, did you get it fixed? Thanks,
Trish
Robinson Sew and Vac
Robinson IL
sewvac75@hotmail.com
Jul 09, 2010 | Royal ALPHA850ML Cash Register
Thermal Printer for Royal 600/601 sc Cash not printing
do you have tape in backwards? one side will print other side will not.
Jun 28, 2009 | Royal Office Equipment & Supplies
Casio Parts Cash Register PC Desktop Logo
186 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
