Question about Karcher 2500 PSI Pressure Washer
Not enough pressure
Got a 2400 psi karcher pressure washer and it is surging. Not a steady spray. We put in a new spark plug. drained gas and carburator. Used new treated gas. Still surges?
  • 5,568 Answers
Speed regulation on small engines is notriously fussy.
Check the linkage to the carburetor and look for a small, light spring.
If there are several holes for one end of it, you may have to try more than one to find the spring tension that lets the engine run steadier than it now does.
If not, then either replacing it or changing the length by shortening or lengthening it will probably be needed.
Posted on Aug 09, 2008
Pressure washer pressure strong but pulsates/surges
check the engine oil and hydraulic pump oil if neither are the case you have a dirty batch of gas. You would need to drain the gas from tank and reservoir then put new gas in it. Water could be in it the filling station could of just got new gas and your gas could of been contaminated
Aug 08, 2013 | Karcher 2500 PSI Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
I have used my pressure washer for a while today cleaning some patio umbrellas. It just stopped and I thought I was out of gas so after adding gas, tried to restart. I could not pull the lever because it...
well did u shut water off to take pressure off if you did that it could possibly be a siezed motor you can take wd 40 and put plenty in spark plug hole and let sit over night and if you can pull it then change oil then try starting
Aug 26, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Karcher 2400 psi washer- no pressure
if the water is flowing
the valves need to change
if no water pistons in pump need to change.
Jul 22, 2009 | Karcher 2500 PSI Pressure Washer
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Gas pressure washer
I have the same problem with a Karcher 2400hh.
Go to: http://www.wmpcs.com/index.php?main_page=page&id=14
they have the best diagrams and answerss that I have found.
May 02, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
379 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
