Sharp Wizard OZ-770
Problem for Sharp Wizard OZ-770
Organizer Oz-770
By dprimo2001 on Aug 09, 2008
The Power on my organizer isn't coming on even with new battery. Help me Please.
Solution #1
posted on Aug 09, 2008
Not Rated)
marked
Rank: Guru
Rating: 86%, 967 votes
If you already change the battery with a new one and still have the same problem this unit may have problem inside its circuit board so if you want you can take it to a repair center near you or check this link tey repair this kind of device http://www.thewizardshop.net/5.html
Good luck.........
Solution #2
Not Rated)
Benimur
Rank: Guru
Rating: 88%, 3830 votes
If I may add to the possible fault as described by marked.
Other possibilities could be:
  • the battery terminal inside the Sharp Wizard OZ-770 are corroded. They have to be cleaned and scraped to ensure maximum contact to the batteries. Further, there may be times that these terminals would have to be bent a little to add more pressure on contact with the battery. If they are spring type, they may have to be stretched a little;
  • a disconnected battery wire, chances are the red or positive wire has been affected by the battery acid and was cut. It would have to be soldered back after a sufficient length has been removed to ensure that no more corrosion exist on the wire. In some extreme cases, the entire length of wire might have to be replaced;
  • the on/off switch. for the diagnosis and repair of the switch, the unit has to be opened and the switched tested with a continuity tester (DVM). Though sometimes it may be cleaned, it is preferable to replace if found defective.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Solution #3
posted on Mar 03, 2009
Not Rated)
chuckie1963
Rank: Apprentice
Rating: 75%, 1 votes
Call thewizardshop @ 803-736-4382 and have them recover the data!
Comments:
Mar 03, 2009
- Have www.thewizardshop.net repair it for you!
Popular Solutions for Sharp Wizard OZ-770
Questions and Unsolved Problems for Sharp Wizard OZ-770
Do you recommend Sharp Wizard OZ-770?
Answer
Answer
viewing screen faded out on my sharp oz-770 pda who will repair it?
Answer
I Downloaded to computer to transfer information but pc sas not found. Can tou assist me?
Answer
my screen is blurry.can it be fixed
Answer
have sharp oz 770 and characters on screen are washed out and some not readable batteries ok any fix... (More)
Answer
I need the software for Sharp wizard OZ 770
Describe your PDAs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
in , PA
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
