Question about Brother HL-5240 Laser Printer
Status red and amber Toner light
I have tried eveyrhing even called brother for helped. they told me to get brother toner for them to help me further. i have tried everything and nth works. my toner light is orange and status light is red no matter what i do pleaaaase help. i have done everthing what u hvae mentioned so far but still the same problem.
  • Anonymous Sep 05, 2008
    I have changed the toner and the red status light and toner light remain on. I ahev shut the machine off, I have replaced the toner, I have un-plugged, I swore and nothing is working.
    HELP!
  • 417 Answers
This problem you are getting is to replace the toner cartridge. Have you recently changed the drum unit as well. If so exchange it back to the other one.
After installing new toner or full toner cartridge and removing the yellow plastic cover press the go button this should start the printer on a cycle and add the toner. If this doesn't work then the toner sensor has malfunctioned and will need replacing. This will in turn out way the cost of a new machine.
Hope this helps and not too late for you.
Thanks Jason
Posted on Aug 17, 2008
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
After printing several hundred sheets, status light went red. There was no paper jam. Let printer "cool down" overnight. Status light still red. Drum has never been replaced. Toner light is on. However, in...
Well, if the toner light is on, you're probably out of toner and the only reason it ran, was because it was low but not completely depleted.
Try new toner drum off of Ebay or Amazon for the best prices for your brother printer.
Jul 05, 2010 | Brother HL 5140 Laser Printer
My Brother HL5250DN shows toner light on (yellow) and status light on (red) even after toner cartridge replaced with new one. Already tried reset by holding down go button. Is the printer dead?
Try this..
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Oct 07, 2009 | Brother HL 5250DN Laser Printer
Alarm light is RED and data light is AMBER - both are on permanently
This means toner is empty. This condition was probably preceded by a period of "toner low" indications, data- and alarm LEDs blinking shortly every fifth second or so (maybe you never noticed that). Replace toner cassette and it should work normally.
Jun 02, 2009 | Brother HL 1440 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Brother HL-5240 Laser Printer Logo
499 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
