Question about Samsung RS2630SH Side by Side Refrigerator
Divider red hot
Fridge and freezer are working fine, temperature-wise, but the divider is red hot. It was making a very strange noise recently too. Any suggestions?
  • dpkar Aug 31, 2008
    Exactly the same problem of divider heat and a strnage noise pattern
  • michelep Sep 30, 2008
    Yes same problem. Divider is actually too hot to touch. You could actually get burned it is so hot!! Seems to be working fine otherwise, but we do hear loud fan noise, more so now than ever before!!
    New Friend:
I had that problem also and i called a repair guy and he replaced the condensor fan motor and put in a bigger blade. he said that these frigs have that problem but mine is now fixed. not hot anymore and working good.
Posted on Feb 22, 2011
    Problem Solver:
  • 12 Answers
Whenever a divider gets too hot to touch it is usually an indication that the condensor fan(the one behind the fridge) is bad.
Posted on Oct 05, 2008
  • 76 Answers
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Posted on Sep 10, 2008
SOURCE:
Bosch double door fridge divider hot, is this normal?
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 09, 2012 | Bosch Refrigerators
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
The divider strip between the freezer and the fridge is super hot. Both sides are still working fine, but it hasn't been this way until the last few days.
When the face of that divider gets really hot, it's because the condenser coils are unable to shed heat properly. Check to see if the condenser fan is running - it's the one that blows air across the coils under the fridge. If no air is moving, then you need to replace it. If the fan is working, then check for any obstructions and use a vacuum cleaner to clean the coils. Make sure there's enough space behind the unit for air to flow.
Jul 22, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore bottom freezer 73504. All freezer items fully defrosted.
I went to local.google.com to find fridge repair person nearby. They were able to come out the same day and solve the problem. The starter kit for the compressor was replaced. Sears couldn't make it until the following Monday when I called them on a Wednesday. I highly recommend shopping local and keeping the home town economy moving.
Jun 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Divider between freezer and fridge is hot to the touch
That is not a problem, it is designed to use "waste heat" from the cooling system to warm this area to prevent condensation from forming there without having to use the extra energy required if an electric heater were used. It will be noticeably warmer while the compressor is running and has been running for a time than if the compressor has been off for a period of time.
Mar 28, 2009 | Refrigerators
Kitchenaid Refrigerator door gaskets are getting very warm.
When the center divider gets hot, it usually means that your condenser fan (the one that blows air across the coils under the fridge) is not working, or that the condenser coils are extremely dirty. Next time the fridge is running, see if there is any air blowing underneath. You probably need a new condenser fan.
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Aug 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
1,368 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
