Question about Philips MMS 321 Computer Speakers
Left speaker doesnt work
I have Phillips Multimedia Speakers 2.0. I installed everything correctly but yet the left speaker still has no sound coming from it. I need to know what to do to fix this. Do i need new drivers or a card for these speakers?? I checked my volume control for the speaker and the sound is up for both and the control as balanced between both. So now i am stuck!! Please help!!
  • desiredafire Sep 11, 2008
    Thanks for posting. I actually right now have it plugged in but only halfway and both work fine. It is weird but that is the only thing that has worked so I have just left it like that for now...
  • XxShadowxXT Dec 15, 2008
    i got the speakers but then lost the cd and my computer wont install without the cd what do i do.
I've got the same speakers & have noticed that depending on the type and quality of the device that i plug them into i'll sometimes only get sound from the right speaker. i've deduced that this is due to the type of output the device offers. for example, if i plug the green tip of the cord into the headphone jack of a television with only one speaker only the right speaker will work. hope this helps
Posted on Sep 06, 2008
6ya staff
SOURCE:
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
I installed a new Sony CD player in my 1996 Toyota Forerunner and the speakers won't work. The player has power but there is no sound. I did not use a wiring harness but I did have the wiring diagram for...
Be sure that the wires are connected correctly. If no sound comes out could be speakers are bad, but highly unlikely that all four would be. Could be the stereo amplifier is out. You could try using an amplifier to connect the speakers. One other option run new wire to each speaker to make sure wiring is still good. Constant 12V+ Blue/Yellow or Blue/Black Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Trigger Black/Red Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 5 1/4" Rear Doors Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White
Feb 14, 2011 | Car Audio & Video
Left speaker works but right speaker does not work [email protected]
Funny, this happened to me just 2 days ago, but I get no sound from the left speaker. Maybe they have all of them rigged to fail at a certain time.
Jul 08, 2010 | Bose Companion 2 Series II Multimedia...
I have a new dell inspiron. I just purchased Logitech x-540 surround sound speaker system. The right front, left front, and center speakers don't work. Everything seems to be hooked up right. Any ideas. Is...
Yes there has to be a configuration for the 5.4 surround sound... look if the hardware came with a CD to update the sound driver. or Check if the its correctly configured. on the control panel then click Sound, then depending what windows you have have to lookk for the configuration or properties area and configure as 5.0 or sorround etc.
Feb 21, 2010 | Logitech X-540 Multimedia Surround Sound...
I can hear sound through midi only
ok my friend i will try with you
just try to install the software of card sound correctly if you dont have drivers just go 2 this web site www.touslesdrivers.com and contact me 2 tell you how 2 install the driver [email protected]
Nov 03, 2007 | Steinberg Cubase SX3
Sound not working
You can goto the manufacture web site for the speakers and download the latest device drivers and install them on your computer.
Oct 07, 2007 | Juster SP-692 Computer Speakers
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Philips MMS 321 Computer Speakers Logo
266 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
