Garmin Nuvi 660 GPS Receiver Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No maps - Garmin Nuvi 660 GPS Receiver
Anonymous
Level 3:
  • Master 368 Answers
  • Posted on Apr 19, 2011
Anonymous
Master
Level 3:
Answers
368
Questions
0
Helped
111951
Points
1142
I am glad to HELP YOU!
If you don't have maps definitely your device becomes useless...
HERE is the GARMIN webpage that will lead you [by clicking the " I agree to the above terms and want to proceed to the download page" - down to the bottom of the page]
to the download area. There you will get the maps and any other upgrade for the firmware.
GOOD LUCK!
... and don't forget to RATE, please...useless...
Map upgrade
Check the map menu to see if the new map is on the unit. At the main menu, press the tools button then the map icon. Then press the "map info" button. Look to see if the listing shows the new map that you just downloaded or if the original older map is still there. Make sure that the map is enabled by a check mark next to the map listing.
Australia zip code
AUSTRALIAN NATIONAL UNIVERSITY 200 -35.18 149.1333 View Map Barton 221 -35.3167 149.1333 View Map BARTON 2600 -35.3167 149.1333 View Map ACTON 2601 -35.18 149.1167 View Map AINSLIE 2602 -35.2667 149.15 View Map FORREST 2603 -35.3167 149.1167 View Map CAUSEWAY 2604 -35.3167 149.15 View Map CURTIN 2605 -35.3333 149.0667 View Map CHIFLEY 2606 -35.35 149.0667 View Map FARRER 2607 -35.3833 149.1 View Map Page 1 ' 2 ' 3 ' next >
My garmin powers down while installin gnew maps.
There are 2 possible reasons for it to say there are no detailed map available. The most likely reason is that no map is selected. Press Tools, then Press Settings, then press Map and then Map Info. There should be a tick beside the name of the map installed on the satnav. If not press the map name to select it. A tick will appear at the side of the map.
The other reason is that the map may be locked. You'll need to go to My Garmin, and then Maps to get the unlock code.
I have 2010 maps on a SD card for my Nuvi. Does
If you already have a map on your unit, you will have both maps. You may have to enable the map on the SD card. At the main menu, press the wrench symbol, then the map icon and then "map info". You should see all of your maps that are available to your unit. Make sure that the square boxes next to each map are checked. Thats how you turn on/off (selct) each map. If the SD card map isn't working, make sure it has a unlock code assigned to the map or it won't work on your unit. Also, the map file name on an SD card is different than the name on your unit. - Jim
3answers
Trying n to up date my tomtom for more maps in the usa
This is from tomtom.com
Hope this helps looks like you haveto pay for map updates after 30 days, but I am not positive.
Application updates
We recommend always having the latest version of the TomTom application installed on your navigation device. This ensures you can use the latest features and improvements available for your device.
To check if a new version is available, connect your device to TomTom HOME and then click Update my device. For more details see www.tomtom.com/6133.
Latest Map Guarantee
Get one free map update if a new map version is released within 30 days of buying a new device.
Start driving with the latest map - guaranteed!
See What is the latest map guarantee.
Map Share™
Get daily map changes from the TomTom community.
In between map releases, you can make corrections to your map – such as road closures, and points of interest – through Map Share™ technology.
See What is TomTom Map Share.
Map Update Service™
TomTom regularly releases brand new maps that incorporate the latest changes to the road network.
With our Map Update Service you get every new release of your map over a 12-month period, from the equivalent of just €9.95 per quarter. That’s four new maps a year.
See the TomTom Map Update Service.
Single map
If you only want to update your map once you can buy a single map.
Buy a single map.
4helpful
DOWNLOADING UPDATED MAPS
See the following options to update maps on your TomTom:
Map Share™
Map Update Service™
3helpful
How to switch between maps ?
Please click on the wrench symbol, then map icon and then "map info". You will see (2) maps listed with check marks next to them. Uncheck the map you do not want to use. Check mark the map you want to use. This is how you switch between maps.
- Jim
SHARCNET-USA
2answers
Changing maps already installed
Hi, Answers to your 2 questions 1 and 2 . ...... 1/ go into PREFERENCES , hit right arow key till you see MANAGE MAPS , Tap that MAP icon and in there will be all the maps you have on the SD card. Select the map you require by tapping the screen. ............................................. 2/ YES , backup the SD card to your PC first. ( you should save everything on the card as it is ) Then delete the Europe map off the SD card and replace it with the USA map . You will need the authorisation code for the USA map in order to activate it. When you return you can swap the maps back again.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
