Question about Dometic RM2652 Refrigerator
Throwing breaker when plugged up to AC
Gas works fine, When I plug power cord into the garage to get ref. cooling before a camping trip the GFI in the garage threw its breaker. I feel that the Power module may be bad. Fuses all look go though.
Any thoughts?
Thanks
  • 51 Answers
The heating element most likely has a short in it. Pull the to leads leading to it test the ohms to see if you have a short
Posted on Sep 07, 2008
This is the solution I rec'd earlier re my De Longhi Pinguino AC 10,000 BTU. If you're in San Diego CA could you make a house call to fix my AC by replacing the cord/plug?\r\n The portion of the plug that...
Never remove a GFI. It is there for a reason. If your plug is has a bad GFI, you can replace the plug with a standard one but make sure you replace where it plugs into with a GFI receptacle which only cost about 30 bucks, or you could replace the breaker that feeds that circuit with a GFI breaker. The problem with replacing the breaker is that if you place any resistance head loads on it (i.e. blow dryer, toaster), it might trip because you get a loss of current from resistance heat. The GFI only looks at what is going in and what is going out. If it sees an imbalance of up to 20 milli amps, it will trip. Your cheapest way is replace with a standard plug and add a GFI plug receptacle to where it plugs into.
Sep 27, 2010 | DeLonghi Heating & Cooling
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
TRIPS BREAKER , IS ONLY PULLING 3.9 AMP. WHAT IS THE AMP RATING ON THE BREAKER
If you are plugging it in a normal garage or outside plug then they are 15 amp GFI. Try running a cord to a Kitchen or bath plug and see if they work. They are 20 amp.
Jan 11, 2010 | All-Pro Propane Garage Shop Heaters - All...
Frig stopped running.
Maybe over pulling more amps the the GFCI curcuit can handle. Check all the GFCI plug and verify if there are anything else plugged in. Including hair dryers and / or flat irons.
Sep 02, 2009 | LG Heat cool Window Air Conditioner
GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Jun 01, 2009 | Whirlpool ES5FHAXS Side by Side...
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Hotpoint refrig 21 cf over and under
Of course it can be plugged into a GFI outlet. Sounds like you have a compressor problem.
Nov 24, 2008 | Hotpoint HSS25GFP Side by Side...
Dometic RM2652 Refrigerator Logo
189 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
