Question about Gateway (4000274) Motherboard
Battery Charger My gateway laptop, model number w323-ui1...It does not register that it is plugged in, so my battery is just dwindling down...My father tested the cord itself and it reads 19 volts...What can I do to fix it? I do not really have the extra money right now to bring to Geek Squad or something if not vompletely necessary...
  • Anonymous Jan 22, 2009
    This is what happen to my Laptop also Now windows wont boot right so one problem went to another. I took it in and they said it was the motherboard and i was gonna cost $400 to fix. So I took the laptop back and I found a Motherboard on Ebay
  • Anonymous Apr 06, 2009
    Same thing-when plugged in does not show charging. I also got 19v but without a current draw,
  • Gateway Master
  • 5,568 Answers
The adaptor supplies more voltage than is needed to charge your batteries and operate the PC so there is a circuit, often mounted on a small, separate board inside the unit that regulates voltage for the PC and monitors and regulates the charge current for the battery pack.
Testing the plug-in adaptor without a load (drawing current from it) is not a reliable way to test it since it could itself be defective and lose some or all of the 19 volts once required to deliver current.
You might try removing the battery pack to see if the PC will turn on without it.
The packs have thermal fuses internally that can fail preventing a charge to take place.
Posted on Aug 09, 2008
Need owners manual for GATEWAY W323-UI1 laptop.
Get onlineand got to www.google.com In the google search box type: "GatewaySupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and Documents.
Apr 09, 2012 | Gateway Computers & Internet
When i move my Gateway W323-UI1 it freezes
that's BAD! it sounds like there's something loose inside your laptop. the only thing i can suggest is flip it over, unplug the power cord, remove all the panels from the back and the battery and shake it and see if anything falls out. while you're in there make sure that you ram chips are securely installed.
Jan 31, 2012 | Computers & Internet
Could you tell me where I could get a user manual for a Gateway laptop, Model# W323-Ul1? Louise
The Gateway W323-Ui1 is also known as the Gateway MX3210,
http://support.gateway.com/support/manlib/Notebooks/MXModels/MXModels.shtml
(No, you did it right. The above page on Gateway is 'Flintstone's' looking)
On the above page scroll down to the heading - User Guides.
Now down to where it states - Notebooks - Gateway - MX3200 series
Click on the file name under this heading -
8511189 - Gateway Notebook Hardware Reference R0 Windows XP
This is a PDF file download. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above link it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
(Took 12 seconds just now. File fully downloaded in that time, with no extra download time needed.
Using medium speed DSL connection)
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 18, 2011 | Gateway Computers & Internet
My gateway M-7031U stops charging at 30%
Unfortunately your battery is probably shot. First though, try to run the battery down until the laptop dies. Now with the discharged battery, and the laptop powered off, plug it in and leave it off for a few hours. Power the laptop back on and check the charge level. Still at 30%? Then the battery is very likely just bad. Unfortunately, the cells in the battery just simply die for a number of reasons, and capacity is lost. This is why most manufactures will only warranty a battery for 1 year.
Take the battery out and write down the model number and the "MAh" or "Ah" number. The MAh number represents the capacity of the battery. The higher this number, the generally longer the laptop runs on battery. Go to http://gateway.shopbysystem.com/gateway-m-7301u-notebook-accessories.html and verify that this is your laptop model. This is a Gateway authorized reseller. Looks like they want $90 for a small battery. Take your battery model number and go to Amazon and look up the battery there. Make sure it's MAh number matches or exceeds what is on your battery. Usually you can get a replacement battery from Amazon for about $20 less than Gateway.
Oct 21, 2010 | Gateway M-7301u Notebook
My brother disassembled his Gateway w323 Ui1 laptop to put in more RAM and a dvd burner, but afterwards the laptop would not power on. When the power cord is plugged into it the light for the power supply...
Yes--take it apart again and check all the connections. As a general rule, if it worked and you "fixed it" and now it doesn't work, then you need to find out what you forgot to do when you put it back together.
Aug 02, 2010 | Computers & Internet
Gateway W323-UI1 Resolution
Try to upgrade the display driver from gateway.com
Jul 21, 2009 | Computers & Internet
Gateway W323-UI1 battery shows charge at 100% but then when unplugged from AC adapter for 10 mins or so it says "critical battery" and if not plugged back into AC adapter right away laptop powers off...
You will need to calibrate the battery. When you boot the laptop, it will say very quickly to enter Setup press F2 (or Delete key) or similar. Do that, you will enter the BIOS. Look for battery calibration and run it. Can take a few hours.
Jun 16, 2009 | Gateway (4000274) Motherboard
No audio or sound only beeps
here some1 gave me this just google a link for this driver ur laptop uses, this i am also finding these drivers from this brand
bcm40100.exe
May 01, 2009 | Computers & Internet
Keyboard on gateway W323-UI1 does not work
yes the keyboard can be replaced on laptops and notebooks.
Apr 15, 2009 | Gateway (4000274) Motherboard
NoteBooks / Laptops
Depending on your laptop model, you may need to press a certain key combination (Fn-F4 or something like that) to enable or switch to the external display.
Look on your laptop's keyboard for a key with a picture that has an L-shaped icon on it (it's supposed to look like an open laptop from the side). Most times you will need to press the Fn or Function key and this key to trigger the monitor switch.
Apr 06, 2008 | Computers & Internet
Gateway (4000274) Motherboard Logo
271 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
