Question about Intertherm Heating & Cooling
I have a 1987 intertherm model mgh 075 aacw 05 furnace in my mobile home. What is the efficiency rating of this model?
SOURCE: smoke coming from furnace
You may have something (paper,dust, etc.) on the electric coils. There may also be a short in the element.
Posted on Mar 27, 2008
SOURCE: I need a wiring diagram
I need a wiring diagram for an intertherm/nordyne gas furnase !!!
Posted on May 26, 2009
  • 10 Answers
SOURCE: Where are the furnace filters in my older furnace?
On these of Furnaces the filters mount on the door. Remove the door you will notice grill on front. There should be a track on the back of the front door to slide filters down. Should take 2 filters.
Posted on Dec 06, 2009
Testimonial: "drifterray really helped. way to go apprentices!"
james1barret
  • 27 Answers
SOURCE: What is an A-Coil Cage
An "a-coil" is a cooling coil that looks like the letter "a". The cage is simply the box or sheet metal case built around the a-coil. It is most likely located inside of the furnace itself and if you remove the furnace door you should be able to easily locate the coil- it has 2 copper pipe tubes running from the coil and down or up through the ceiling or the wall.
Hope this helps, James
Posted on Jan 05, 2011
Testimonial: "Thanks very much. I have ask everyone Iknow and got no answers. This has really helped me out. Paul"
SOURCE: 1990 Triple E mobile home
I've a similar problem and a new thermocouple solved it
J. N. Millet, Alberta
Posted on Jan 14, 2011
I have a Intertherm furnace model# MGH-065-ABRN-05...The target burner needs to be replaced. I type in my model # and it isn't reconized. Is this a good number. Thank You
I don't think that is a good model #. Here is a link to their site and the furnace models there have a totally different type of #.
http://intertherm.net/Products/Furnaces/GasFurnaces.aspx
If you really need the burner, Id call Intertherm and then they can tell you what data plate you should be looking at.
http://intertherm.net/DealerServiceLocator.aspx
Jan 02, 2018 | Intertherm Heating & Cooling
I wonder if you have a picture of where the therm couple is inserted next to pilot for a intertherm mgh 055 furnace
try going to YOUTUBE and insert (intertherm mgh 055 furnace) in the search window for illuminating videos
Dec 22, 2017 | Intertherm Heating & Cooling
I have a Intertherm model MGH-075-ABWN-05 and the A/C stopped working. someelectrical problem i'm guess.neither the blower fan nor the outside unit are running at all
Check the drain line for a float switch. Remove float and check for water. Do not leave float out, you must clear the drain. Good Luck
May 10, 2017 | Intertherm Heating & Cooling
Looking for a gas valve for a intertherm furance model no. mgh-055aacwl-06 ser.number mgh9009-00077
you need to contact your nearest a/c supply house. most company's that sale parts on line will not sale gas valves to the public due to liability.
May 15, 2014 | Intertherm P3RA-048K Air Conditioner
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
No problems, would like to find out the best way to remove blower for cleaning on an intertherm gas furnace mgh 075 ina mobile home
Generally ther is two screws at the base of the blower housing which hold it in place, remove the screws and pull, slide the entire assembly out. You will have to disconnect the electrical wiring to the blower and possibly the limit switch on the side if equip.
Aug 23, 2011 | Dayton Gas Furnace Heater
Open the door to the airhandling unit inside the closet by lifting upward on them. There should be two filters located on top of the A coil.
Dec 05, 2009 | Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
