Question about Refrigerators
Crosley CS21B5D We do not know how to hook up the ice and water dispenser. Help would be appreciated.
fridgetech
  • 473 Answers
SOURCE: How to hook up Ice & Water dispenser on freezer door
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Posted on Oct 06, 2007
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
  • 146 Answers
SOURCE: Ice dispenser only dispenses crushed ice
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Posted on Dec 26, 2007
  • 184 Answers
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
My kenmore side by side is not making ice
when was the last time u change your water filter, if water is coming into the ice maker and it don,t make ice that means u have a defective ice maker, if no water comes into the ice maker check the water valve at the back of the refrigerator with an ohm meter for resistance if no resistance is present replace water valve,u should unplug water valve when checking
Jan 16, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice dispenser will not dispense ice, but it will dispense water
It might not be hooked up right. Or there could be something blocking the ice dispenser.
Nov 28, 2012 | Refrigerators
My icemaker stop working but the water dispenser still working I check both water lines from the filter its ok but can't check the freezer line by icemaker. turly don't know why the water will not flow...
If there is no ice in the ice mold of the ice maker, you can pour enough water in to make cubes, wait an hour or so for the icemaker to cycle.( freeze and dump the ice). If it does, then your water valve on the back of the refrigerator that the main water line hooks up to is bad. Replace it. The valve has two sides to it. An ice maker side and a water resevoir side. One side can be bad allowing the other to work.
If the ice maker does not cycle and dump the cubes then you probably have an ice maker problem.
Jun 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser/water dispenser in side by side fridge not working
Your dispenser is child locked. Hold the child lock button for 4 seconds and the key should disappear, if you do not know which key to press I will need the model number from the tag located on inside of the fresh food section top right corner.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Water line hooked up makes ice but no water from dispenser
Have a look at the back of the fridge. There are 2 valves that feed the ice maker and the water dispenser. Have someone push the dispenser button while you feel which solonoid activates.Once located,remove that single pipe from that valve and reactivate the dispencer button. If water shoots out then you know the problem is further on. I would suspect there is then an issue with the water filter. Remove it and inspect for defects. If the filter is old, suggest you replace it as they clog up reasonably quickly. Retry. Please let me know.
Oct 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE Side by Side Refrigerator dispenses ice but no water
if the light is not coming on i would say that board needs replaced and it just pops right out
Mar 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
