Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hover F7452-900 My brushes are not turning. I have taken the tanks off to check the switch that changes from carpet to hard terrain to Ceramic tile.I noticed that there is a spring that has came off. I tried to disassemble the top half (nose) of the cleaner but I have came to a stand still. I cannot figure out how to remove the cover so I can figure out where the spring should be attached. I have removed all the screws that are visible and it still won't budge. It is loose but on the back side of the cover near the wheels it seems to still be screwed in. I don't want to break it to find out
  • shawbria2 Aug 18, 2008
    I was able to remove the cover and reattached the spring, this fixed my problem. I did however notice that if you do not have a good seal located between the bottom tank and that rubber seal your brushes will not turn.
Regarding the brushes not turning:
Your filter may need to be cleaned. It is located behind your brushes. With your tanks removed and the cleaner unplugged; tilt your cleaner back. The filter screen located behind your brushes can be removed by squeezing the sides of the filter and lifting and pulling toward you. Clean and replace.
It would be difficult for me to advise you any further without seeing exactly what you have done.
Posted on Aug 09, 2008
Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
See if the following information can help.
CARPETS OR HARD FLOORS
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
How do I change to different powers
Hi there, it's Jack at Dyson.
DC24's brush bar is powered by its own motor. This means the brush bar can be turned on for carpets and rugs, and off for hard floors or delicate rugs.
To turn off the brush bar, just press the silver brush control switch located next to the red on/off switch. Press it a second time to turn the brush bar back on.
I hope this helps, but if you'd like any further advice you're welcome to contact our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 25, 2014 | Dyson DC24 All Floors Upright Cleaner...
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Jul 26, 2014 | Hoover F7458900 Max Extract All Terrain...
Carpet
have a look at the brushes are they turning and if they are can you stop them turning if you tuch them with your hand??? if you can stop them turning the brush drive belt is slipping get a new belt and fit it,,
problem sorted!!!!
Jun 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Irobot roomba brush only spins on hardwood/tile. brush stops when it hits carpet. motor prob's? fix?
Remove and clean the yellow bearing on each brush, then reinstall them. Run the Roomba and ensure that the brushes do turn on hardwood, then test it again on carpet. If the brushes still stop turning on the rug, call customer support at 1-877-855-8593. They'll be able to determine your warranty status and discuss your options.
Aug 05, 2009 | iRobot Roomba 4300 Robotic Vacuum
Hoover f7452900 brushes wont turn?
make sure that you have it on the carpet setting and not the hardwood/tile setting. also if you used the hose, make sure that the little door is closed. if all checked... remove the recovery tank, there should be a rubber grament on the stand pipe under the tank, if it is there, then it would have to be the turbine assembly that drives the brushes
Jul 20, 2009 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
All terrain steam vac
Try and trace the hose back from the brushes to the pump. The hose could either be disconnected, kinked, or clogged.
Good luck - Tech101
Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
98 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
