Question about Toshiba 46HM95 46" HDTV
Toshiba 46HM95 White triangle shadow
I have a 46HM95 and it has been a great TV. Just recently I have been noticing a white shadow on the middle bottom of the screen shaped like a triangle. You don't really notice it that much except during certain scenes and if you approach the tv from the side. I recently replaced the lamp, but that did not seem to have any effect. Does anybody have an idea what the cause may be?
  • 1 more comment
  • Anonymous Aug 23, 2008
    the
  • rudy211 Aug 23, 2008
    tv turns on and works fine for 15 mins then the picture starts to flash mostly blue and purple if your watching sports you can see the words at the top flash and show up in different spots i just changed the lamp and it half fixed the problem but only if the tv is set to high bright setting on lowpower setting it still does it.
  • Anonymous Oct 22, 2008
    I also have a 46hm95 and have both the white triangular shadow and the loud buzzing. I had the light engine replaced once, and it is back. As for the buzzing, I am going to try to replace the fan module. Unfortunately, I have called Toshiba and they do not seem to be very concerned with helping me fix this problem. I asked about a "no lemon" policy and they said they do not replace parts or televisions even if it has to be repaired 20 times. This is the last Toshiba product I will buy.
I have the same problem with my television i was told it needs a light engine the cheapest one around is $500.00 and that does not include the cost of repairing it. All I have to say is enought people write into toshiba with this complant if enough people write maybe we can get them to replace it for us.
Posted on Oct 14, 2008
Turn on TV hear a buzzing and then the TV cycles off and on again
Hi,If it seems you are experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.I found it with complete light engine assembly here: http://www.discount-merchant.com/TOSHIBA-2973026206-p/1160068.htm?Click=48173
Apr 16, 2010 | Toshiba 46HM95 46" HDTV
Sound but no picture, tv turns off and on
It sounds Lamp is dead in your TV, how old is this TV and did you replaced its lamp recently?
Click Part Store to see required lamp image and price info.
Nov 02, 2009 | Toshiba 46HM95 46" HDTV
Shadow along side
does this shadow go from top to bottom on the left or right side app 1" to 2" wide ? if so your light engine needs to be replaced
Jan 17, 2009 | Toshiba 46HM95 46" HDTV
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Hitachi Ulatravision Digital TV....... have a yellow shadow around part of picture
it might be scorch mark starting from the bulbs heat or someone placed a magnet close to machine that gives the same impression
May 09, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
i suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Mar 21, 2008 | Televison & Video
Sony KP-61HS10 Rear projection TV blurry /shadows at first start
Sounds like the convergence ic's need to be replaced or resoldered. Sometimes it can be a microfuse if you are lucky. But my question is if you hit the focus button up front does it make it thru the auto convergence? Let me know. Have a good one.
Feb 09, 2008 | Sony KP-61HS10 61" Rear Projection...
MY TOSHIBA 46HM95 TURNS OFF BY ITSELF...
Sounds like earth problem with your Electricity. Your tv think there is some kind of a short then go in to protection. If i am wright, when you touch the ground and some applience, does it shock a little bit, if yes im wright.
Dec 15, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95 46" HDTV Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
