Hi.
Check that the drain hose height and elbow setting is correct, or the problem will be giving by water re-fluxing into the appliance from the drain hose.
Access the filter and clean it.
Check for blockage at drain pump hose.
Replace the filter if you have not done it yet.
Check and clean the hose connected to pressure switch.
Here a general article that I wrote about no-spin problem: If you have no spin ...
Regards.
Ginko
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please back for any further assistance.
Daniel
