Question about Samsung Televison & Video
I Grought an samsung PS50q91hd yesterday, it can tune the analogue channel, but it can't search the digital channel. i was told buy the sales that the tv has build-in hd tuner. can anyone help? thanks.
  • 11 Answers
SOURCE: Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Posted on Nov 04, 2007
HDTV GURU
  • 261 Answers
SOURCE: Digital channels off the air on Sharp LCD Tv
Yes, Go into menu and make sure you have at least rabbit ears hooked up and preferably a HDTV Antenna. If not, a Large paper clip will work in a pinch if you have one, but it won't pick up all channels. Give that a try and then go into the menu under search digital channels then, after you find a few, see what the signal strength is and go from there. Let me know how it works out for you and please give me a good rating. I am trying to do this to make some cash as well. Good day and happy HDTV ING. JAY
Posted on Feb 01, 2008
chrispurs1
  • 372 Answers
SOURCE: samsung tv problem
Hi.
You havent listed your TV model but most Samsung sets that are digital will have A button on the remote marked DTV this will tell set to look at the digital chans.
Now try & go in to the menu & select tuning & scan the digital chans in.
One other thing are you in an area of the UK that can pick up digital channels without changing your aerial.
http://dysonmanuals.llc.nu/
Chris..
Posted on Mar 07, 2008
tvtek
  • 1284 Answers
SOURCE: Digital TV Tuning problem
I would try letting the set autoprogram again.
Posted on Mar 08, 2008
  • 4234 Answers
SOURCE: I have TV Model #DS27425.
This particular set does NOThave a digital tuner. However, if you have cable or satelite, a converter will not be needed. Only if you use an external antenna will you require a converter box.
Dan
Posted on May 08, 2008
Just got digital service, can't tune the stations
Check and make sure that your TV has compatibility tuner [analogue / Digital] provided inside. If not, you have to buy a digital to analogue converter to receive digital transmission. Refer the device user manual for details. If f the tuner is digital/analogue compatible; and you can't receive digital channels, it is faulty. The tuner have to be replaced. http://electronicshelponline.blogspot.com/
Dec 06, 2015 | Televison & Video
Connecting Digital Decoder to Analogue TV.
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
Sep 14, 2008 | Televison & Video
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
How do I get my Sky channel back on analogue after re-tuning freeview
Go in to analogue tuning. Tune just the analogue side of the TV.
Sep 05, 2014 | Televison & Video
Not recieiving tv channels
Are you talking about digital, analogue or satalitte channels? Have you ran the "menu/channel/ariel or auto tune" procedure If yes and channels were found; have you tried "source input" button o your remote? Have you tried "menu/support self diagnosis or contact samsung? If all else fails contact samsung support - who I've found to be extremely helpful. Good luck
Dec 26, 2013 | Samsung 6350 Series UN55F6350 55" LED...
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
I cannot retune my samsung tv- model no LE37C53CF1W- COULD YOU ADVISE HOW TO RETUNE, mANY THANKS, Jim Lauder
Hi,Does the icon look like a large satellite dish?
Make sure your TV is on "TV" and not "DTV" before retuning.
To re-tune analogue channels:
I have a Samsung TV and that icon is not accessible from the menu if i am watching the tv on the digital option of my remote. You have to switch your tv to the "tv" option on your remote and you will be able to access the icon from your menu.
(on your remote, you should have a button with TV/DTV on it)
To re-tune analogue channels, if you want to re-tune digital channels, then look for the "D MENU" button on your remote. Press this then scroll down to the icon that looks like a large satellite and then on "Auto Store" This will re-tune your digital channels :0)
Take care and hope it helped.
May 28, 2011 | Televison & Video
I need a user manual for a Techwood LVD2263D flatscreen tv. I cannot install & re-tune to view TV channels
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 23, 2010 | Televison & Video
I have lost digital reception. I can play DVDs and get analogue TV.
You need to make sure your reception is strong enough to receive digital reception otherwise you will only receive analogue reception and dvd playback ability is normally nothing to do with the TV's reception.
Ensure you have strong reception before doing an auto tune to search for the channels. Good luck.
Sep 14, 2010 | Sony KDL-52XBR9 52 in. LCD HDTV
Cant access the digital menu since the digital change over. Still recieve analogue channels 1 to 5 samsung lcd tv model LE32N73BDX
Hello Gregor_69
Lets see if we can get you sorted out. Please follow my steps and you will be back up and running in no time.
with you samsung remote make sure you press the TV button so that we are on a TV channel and not one of the other inputs.
Then press MENU
down to CHANNEL
go to AUTO STORE
you should find two option on there 1. air 2. cable
You want to highlight the air and START.
it will now give you 3 option
Digital & Analgue
Digital
Analogue
highlight the Digital option and START.
This will auto tune just your Digital channels. Once this progress bar has finished. You should find that all your Digital channel have returned to normal.
I hope that this has helped you out. If so then please leave a thumbs up
Cheers
Little Dish Fitter.
Oct 11, 2009 | Televison & Video
Televison & Video Logo
97 people viewed this question
Henry  Thomas
Henry Thomas
