Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Both sides are warm
My hotpoint is three years old. i've already had a repairman 1 1/2 years ago. The temperature is warming up and everything is thawed out. It makes a loud noise like a clock ticking. Is it anything I can fix or is this another call to the repairman for what seems like a temporary fix ?
    Sergeant:
  • 409 Answers
Can yiou tell me what the repairman did? the ticking is the air damper but the cooling is a separate issue. call a different repairman to have them take a look at the compressor, heat exchanger or evaporator as these could all the be source of the problem.
Posted on Sep 13, 2008
KFIS29PBMS00 gets warm after a day of work
sounds like you need a repairman's services
Jun 24, 2015 | KitchenAid Refrigerators
It is three and a half years old and ices up even at warm temps.
The problem you're having is generally caused by the air intake filter needing to be removed and cleaned and/or the cooling coils need to be cleaned.
I assume you already know how to remove and clean the filter, since you've had the unit for 3 1/2 years, so I won't bore you by addressing that.
The coils can be cleaned with warm water and a mild dish washing detergent using a sponge or rag. Once they have been wiped down, rinsed and dried, apply a light coating of WD40 to the coils.
Hope this helped you & thanks for choosing FixYa.
Sep 19, 2011 | Kenmore 54701 Dehumidifier
I have a Performa side by side 7 years old, had a repairman out because it started running constantly...Dx was there is a freon leak. Isn't this uncommon for a fridge that is not THAT old?
It happens alot in my 18+ years i have seen them leak 1 day later to 30 or 40 years later.If it was running and not stoping and freezer and fridge warm or hot it may be a leak if it runs alot and freezer is cold and fridge warm then it is not a freon leak.
May 18, 2010 | Refrigerators
Have a GE GSS22KGMA side by side. Fridge gets warm at the top
Hi and welcome to FixYa. I am Kelly
I am going to paste part of your text and then reply:
Your text:
Repairman came back and replaced a small round part at the top of the evaporator (resistor??) <
{ That was the termostat}
I just read that the problem could be the defrost thermostat..
He already replaced it.
I hate to say it but is sounds like your in repairman hades.
So far I see 1. a new mother board, 2. new defrost thermostat and 3. new defrost heater element. (other than wiring that is everything in the circuit)
Either one of the 3 NEW parts is bad or...there is a partially broken wire in the circuit.
Hopefully this helps you understand. ( I know it does not fix your uint)
Thanks for using FixYa.
Kelly
P.s your words again:
one would expect this to be remedied.
You got that right!
Feb 11, 2010 | Refrigerators
I have a HTR16ABSARWW Top Freezer Refrigerator in
You need to warm up the garage for it to work right. The cold control reads the refrigerator temperature and if it's already cold, will not turn on the compressor. Hence the freezer warms up to the ambient temperature.
Jan 06, 2010 | Hotpoint Refrigerators
Maytg Top Mount Freezer drip tube leaks into bottom of Refrigerat
Just had this problem a few weeks ago. tube from freezer was frozen solid 1-2 feet down from the freezer. Empty EVERYTHING out of the the Fridge and the freezer into coolers or other suitable 2-4hr container(s). Unplug the unit and use a hair blow dryer on the coolest warm setting. If it's too hot it may melt plastic or styrofoam parts. As long as long as you have everything out and it's going to be at room temperature for a while, why not clean it totally out with fantastic or your favorite cleaner. Once your sure the clog is gone from the tube, put it all back together, plug it in and stop being a slob and keep it clean!!!! hehehehehehe
Sep 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have kenmore side by side it seem very warm between frige and frezer by door handle never felt warm before (26foot elite) about 4 years old
i pulled the frige out to clean around the coils only to find the cooling fan was not hooked back up buy the last repair man that changed a thermostat a month ago be for i put my tool away it was ok
Feb 20, 2009 | Hotpoint HSM25GFRSA
Hotpoint HSS25GFPA side by side
If the freezer is packed to the top and the air ducts are blocked it can not share the cold air with the refrigerator and it gets warm. If this is the problem, then the next day it should get cool again! let me know.
If you decide you need service!
Here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Sep 02, 2008 | Hotpoint HSS25GFP Side by Side...
Have 16 yr old Kenmore model 106.9537622. The heater strip at the center divider between freezer and frig gets real hot for a period of time everyday and causing frig and freezer to be too warm. The...
if this is a side by side refrigerator, then the space between the doors is not heated by an electric heater. it is heated by part of the condensing coil. so the excess heat is probably generated by a loss of adequate airflow under the machine. which would explain the temperature change in the refrigerator.
  • clean the coils under the machine and make sure the fan is working.
  • make sure the airflow is not obstructed in any way.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 01, 2008 | Refrigerators
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
