Question about Rinnai Heating & Cooling
Our heater 556ftr is got a code error flashing, 14
I found the manual on the net and it said error code 14 is overheating, it suggests to clean the filter, but my filter was clean, so I'm wondering if my flue has been installed incorrectly. On mine the error code is staying on after switching the power off and on, so this means my thermal fuse has blown.
Posted on Oct 14, 2008
Can a Rinnai 556FTR (2010) flue be converted from straight out the wall - to out a chimney?
No, Rinnai manufacture other models with a conventional flue.
Most models these days are balanced flue for ease of installation.
Jan 07, 2014 | Rinnai Heating & Cooling
I have a paloma PTG 74PVP-2, error codes C2 14 flashing?
Before calling service technician, or Rheem, copy following link for troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error 14 is low manifold pressure, cracked heat exchanger, restricted air flow.
C2 can be dirty combustion parts, bad gas solenoid valve, bad circuit board.
Combination of these two error codes implies possible PC board failure, which is similar to failed motherboard on computer.
Suggest that service technician perform the required yearly maintenance to see it that fixes error code.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Aug 25, 2012 | Rheem Water Heaters
My Bosh 24ES has error code 14 what does this mean and can I fix it
The year 2009 Bosch 24ES manual does not show error code 14.
Your manual may be different.
Call Bosch 1-800-642-3111
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch-GWH2400ES.pdf
Don't forget to read the product manual for required yearly maintenance, and performing this maintenance will eliminate many common error codes.
Aug 09, 2012 | Water Heaters
My Rinnai heater starts then stops after 5 -10mins flashing 14.
14 is an error code alerting you that the unit is heating up too hot. Check the air filter and make sure it is clean. You may have to take the front panel off and inspect the burner area for any signs of overheating. Remove the trim panels closest to the wall and clean out any debris from behind the heater. Let us know next time what model you have. Good luck!
Mar 30, 2011 | Rinnai Heating & Cooling
Fault 14 on rinnai energysaver 556ftr
Hi.
Error code 14 is Overheating error.
The error can be caused by the high limit sensing overheating and cutting off. In that case the thermal fuse may not blow. The high limit can be reset tripping circuit breaker and allowing the unit to cool down with power off.
If that does not work , then the thermo fuse has blown
In fact tis unit has a thermo fuse. (refer to manual).The thermal fuse can be tested reading continuity. If thermal fuse has blown, then replace the the thermo fuse. If the thermo fuse blows again, then there is a condition causing overheating. b260351.gif
Here Full service manual.
Unless you are a trained technician call Rinnai support ringing the number in the manual. Some of testing and repair operations described are not suitable for the home user.
Regards.
Ginko.
May 31, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Error code 11 on a Rinnai energysaver 556FTR
Rachel,
The 11 code means Missed Ignition. This is a broad error code. It just means the stove did not light when it was supposed to. I would check the fuel first to be sure the valve is on and you have gas. Next, try to start the stove with the room dark. Look into the window to confirm a sparking. This is the igniter. At the same time be sure the combustion motor is running. You should be able to hear it and feel the stove to confirm this. If the motor does not turn or the flue is blocked you will not get any gas to flow. Look outside to confirm the flue is not blocked.
Keep us posted,
Tom
May 29, 2010 | Rinnai EnergySaver 556 Air Conditioner
PTG-74PVN Error Code -0 14 and LED on the controller board flashes 4 blinks every 6 seconds. Fan turns on few seconds after power up then stops. No fan, no spark, and no fire when water flows. Where can I...
code 14 is a big deal shut that thing down! you will burn it up if you keep running it, your over heat wrap on the heat exchanger is too hot. call rheem they can walk you through it
Aug 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
Flashing error code
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Dec 20, 2007 | Toshiba e-Studio120 Copier
Heating & Cooling Logo
431 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
