Question about Linksys Wireless-G WRTP54G Router
User name and password
Just bought a wag200g. and got no user name or password for the initial set up, can you help?
  • 611 Answers
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and
click the Properties button.
4. then you give the this ip address in box 192.168.1.52 subnet mask 255.255.255.0 and defaultgatway is 192.168.1.1
then give ok,ok,ok
after then you go to the start>run>type ping 192.168.1.1 -t after then enter its reply come then you go to the
internet exploere in the address bar type 192.168.1.1 end enter
then ask you user name and password
admin and admin.
then configure it.
Posted on Aug 11, 2008
  • kalpesh jain
    kalpesh jain Dec 20, 2008
    you just go inside the router after that you have to give the user name and password by default you type in the internet exproplere in address bar just type 192.168.1.1 . then by default username is admin and password is password
  • kalpesh jain
    kalpesh jain May 07, 2009
    user name keep 1.blank.
    2.admin
    password :1.password.
    2.admin
    try both combination ok
What is my Gmail account?
I can partly help you suggestions to find these out Usually, users chose their first name's initial and their last name's initial, or their full name and a significant number for a User name; Security professionals suggest not to use the birth year or birth date for numbers in the User name. Your password can be difficult to find out if you did not leave yourself a hint to remember it. In this case, you should contact the Admin at Google and ask them to first find your gmail account, and second to remove the existing password from that account so that you could create a new password for it. I hope this would help you to resolve these issues.
Aug 29, 2017 | Computers & Internet
My Linksys wcg 200 is a hot spot. How do I put a password on it?
Straight from the users manual:
How to Access the Web-Based Utility To access the web-based utility, launch the web browser on your computer, and enter the Gateway's default IP address, 192.18.1.1, in the Address field. Then, press Enter. A login screen appears. Use the default user name and password, admn, unless you have changed them during the Setup Wizard. (You can set a new user name and password from the Administration tab's Management screen.) Click OK to continue. Here is the whole users manual. http://www.visiosys.com/support/documentation/06_Transmission/Modem_&_routeurs_WiFi/Linksys_WAG200G/WAG200G_Installation_manual.pdf
May 24, 2011 | Linksys WAG200G Router
I have done a hard reset for my router, I tried the suport page but it did not help... I want to know the default username & password.
To access the web-based utility, launch the web browser on your computer, and enter the Gateway's default IP address, 192.168.1.1, in the Address field. Then, press Enter.
A login screen appears. Use the default user name and password, admin, unless you have changed them during the Setup Wizard. (You can set a new user name and password from the Administration tab's Management screen.) Click OK to continue.
You may refer to WAG200 User Guide if required. (Page-5&7)
Feel free to contract me for further assistance
Hope it helps! Good Luck!
CreativeTECH
Feb 14, 2011 | Linksys WAG200G Router
I forgot DSL user name and DSL password for my linksys WAG200G
You'll have to contact your Internet Service Provider(ISP) and ask for the DSL username & password.
Jan 29, 2011 | Linksys WAG200G Router
I have WAG200G linksys modem, I need to know how to set a password to my home network so that nobody can access my network
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar. Open an Internet browser. Type "192.168.1.1" (the router's default IP address) in the address bar where you normally type URLs. Press "Enter." Lookup for the options to do the following (Default IP Address, User Name and Password are written at the back of the router): -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password admin.)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.Click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet. You may refer to WAG200 User Guide if required.
CreativeTECH
Jan 28, 2011 | Linksys WAG200G Router
I just want to change my router password..its wag200g.. can you tell me please?
If you have forgotten your wireless security password then you need to add new password because it is saved in * and # format so you need to add new code.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 16, 2010 | Linksys WAG200G Router
How to set up after resetting the WAG200G?
connect you router with your PC or laptop and then type http://192.168.1.1 in your Internet Explorer.
Use Admin Username / Password to enter you setting area for configuration.
Apr 09, 2010 | Linksys WAG200G Router
Dsl user name and password
connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"Let me know if you need further assistance.
Nov 20, 2009 | Linksys WAG200G Router
Please help me to save SpeedStream 6300
Maybe try pressing the reset button on the back of the router. It'll reset everything but at least you'll be able to get into your router
Jul 12, 2008 | Siemens SpeedStream 6300 (33A6300001)...
Linksys Wireless-G WRTP54G Router Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
